My exhaust manifold is cracked. How hard are they to replace?  Where is the best place to get one? I will go back with stock , unless that is not a good idea.
  • Replies 36
  • Views 8.1k
  • jlbayes
    jlbayes
    I have seen just as many 3 piece manifolds cracked as I have the stock one piece. I had an ats that was cracked terribly.
  • Agreed everything is breakable and quality is generally the main variable why things do. But over the many years I've always understood exhaust manifold cracking was nothing to do with shut down
  • You can drill and tap it for your EGT gauge before ever installing it.
Are they the same? Just block off the EGR?   The order says it is for my 24v.
That is the wrong manifold.  24V have round exhaust ports.  12V have rectangular
Make sure you sing the little "Rock Auto..." jingle when you do
On 4/20/2018 at 9:57 AM, KATOOM said:
If mine ever cracks I'll likely replace it with a 3 piece simply to avoid it ever cracking again and because the come pre-drilled.  Thats me saying that now though...
That right there is valuable information...  Thank you.  There's no need extra spending money to solve something if its not solving anything. :thumbup2:
You're welcome. I am in much favor of the one piece stainless manifolds (regardless of manufacture). Steeds work as well but they kill spool up due to the CSA (cross sectional area) of the manifold.
You could replace a cracked OEM manifold every few months for the price of a stainless. :thumbup2:
Or you can be like me and not even bother because the exhaust manifold never cracked and I'm at 341k miles and rolling yet.
I just installed a BD stainless manifold.  I'm really happy with it.  There is a noticeable difference in performance.  My original manifold cracked out where I had installed the pyro probe years ago. Only had it on for a few months now but I like it.
Why I buy mine used LOL
Got hopefully the correct manifold this time.  When I drill for my EGT does that only monitor the last three cylinders 4 5 and 6?
The back three cylinders run the hottest due to air flow and coolant restrictions, numbers 5 and 6 specifically.  Knowing the exhaust temp of those three is most important.
Got the broken one off, new one on, just need to torque it down, install the turbo and drink a beer, not a bad at all. Raining here now so I will have to drink two beers.  Thanks for your help guys and gals.
