- Replies 20
- Views 6.3k
Marcus2000monster 5 posts
dripley 4 posts
JAG1 4 posts
Nnickdd 4 posts
Popular Days
Fuel pressures should go no lower than 14 psi or like Moparman says, ''your causing a slow death to the VP''. The problem is the fuel lost the lubricity these injection pumps need when they changed to
2001-2002 are the strongest built ECMs. The 99 ECM is the most prone to failure.
They most have slipped me an old one. Mine died in 09. Never knew what caused it. I did end up with a new Cummins ECM and not reman.
I've been learning a ton of information thanks to this forum. Here's where I'm at. Loss of power much more frequently as of last few days. Originally key trick gave me P1693 and p2016. I've had this truck about 7 months now. Replaced lift pump with a fass ddrp soon after I got it as a precaution due to advice by a friend about lift pump failures. Hadn't even checked for codes at that point. Since then I wish I would have upgraded a bit more and relocated it. Still in stock location as of now. Anyhow I had started to notice a brief bit of white smoke on startup and truck has no power at times. Always starts right away. I have checked fuel pressure and have 17 psi idle and drop to 11 wot. After checking with a scanner now I have p1698 and p2016 according to the scanner. Is it time for sure for a new vp44, and how much will a fuel line kit at least from filter to IP help? Thanks to all for this forum. May have forgot some info, didn't want to be too long winded.
Edited by Nnickdd
