Bulletproof mods
Mods that I have that benefit my 2nd gen...
Gauges
 Fuel pressure with led light
Egt
Trans
Fuel system half inch, air dog set at 19 psi
Deep dish trans pan
For the future...
Latest mod to wiring (Not sure of name)
Trans rebuilt (this summer?)
Going to check/fix killer dowel pin
Pull out dent mom in law gave me.
Towing mirrors
What are your bulletproof mods?
  • Replies 49
  • Views 15.8k
    Oh... I can't resist...   Dripley even got a built-in trough for routing the chicken grease to the fuel tank. Biodiesel anyone?
  • Dripley forgot the chicken roticerie over his exhaust manifold. Even got a 'Chicken Done' gauge on the dash.
  • cajflynn
    cajflynn
    Because my 3rd gens all had injector problems.  I blew quite a few motors after an injector or two got stuck open.  My 4th gens have been far more reliable.
That truck is a 2016 with 270k miles on it.  I had a 06 and 07 that lasted about 500k each.
Why did they only last 500k?
Jeebus that is a ton on a 2 year truck!!! I would have never guessed it had 270k on it! My 01 has 310k now and it looks like hell.....
The legend himself, nice to meet you sir. I'm with you on 4th gen if I ever get a newer truck I'm skipping over 3rd gen straight to 4th like i did with pagers. Glad to see you still around.
9 hours ago, cajflynn said:
Did someone say my name?
So good to meet you sir! MY I ask of the engine has been rebuilt?
Nice to meet you too.  I haven't been here in a while. It's nice to see everyone still marching on.
My 01 was never rebuilt.
Did it ever crack? My 53 did around 290k I think now I have a Taco Block
No.  Mine never cracked.
Wow that is crazy!
5 minutes ago, Marcus2000monster said:
Wow that is crazy!
@cajflynn is my inspiration on the 2nd Gen. After watching him cross 1 million miles I know anyone can do it. Just sad to see 3rd gens 500k lifespan. Ive actually heard lower like 300k miles. Then the expense of replacing injectors too.
Dads 06 made it to 460 and he sold it and he has stayed in contact with the buyer. He is almost to 500k but he truck has quite a bit of blow by
Nice to see a few made close to 1/2 million. Like around here most of them seem to be blown up around the 200-300k miles range.
That’s awful. They should easy make 600k
I used to test blowby by removing the oil cap and set it back down on the fill hole upside down.  If the blowby was so bad the cap fell off, the motor was done.  If the cap didn't blow off, I kept going and checked it regularly.
Edited by cajflynn
I've heard that like 95% of blowby can be fixed by pouring some product into your oil I believe and it'll remove the carbon. They use it on semis from what I've heard.
It sure is nice to see the legend return. I hope you can keep in touch with us :cummins:
L8tr
D
Also by not having any vacuum leaks and a good crank case vent
5 hours ago, Dieselfuture said:
@cajflynn what oil did you prefer on 2nd gen and what do you use now
Delo on my 2nd gen. Don't care on the 4th gens.
