Bulletproof mods
Mods that I have that benefit my 2nd gen...
Gauges
 Fuel pressure with led light
Egt
Trans
Fuel system half inch, air dog set at 19 psi
Deep dish trans pan
For the future...
Latest mod to wiring (Not sure of name)
Trans rebuilt (this summer?)
Going to check/fix killer dowel pin
Pull out dent mom in law gave me.
Towing mirrors
What are your bulletproof mods?
  • Replies 49
  • Views 15.9k
    Oh... I can't resist...   Dripley even got a built-in trough for routing the chicken grease to the fuel tank. Biodiesel anyone?
  • Dripley forgot the chicken roticerie over his exhaust manifold. Even got a 'Chicken Done' gauge on the dash.
  • cajflynn
    cajflynn
    Because my 3rd gens all had injector problems.  I blew quite a few motors after an injector or two got stuck open.  My 4th gens have been far more reliable.
54 minutes ago, cajflynn said:
Delo on my 2nd gen. Don't care on the 4th gens.
What’s your thoughts on Rotella T?
 sorry to keep bugging you, but was second gen all stock, did you have bigger injectors, gauges, what was the limit on your egts when towing all that time. Just trying to figure out how to make this thing last even 500K already had to have a machine shop put new valve guides in at 156k which is sad. I know a lot of your miles are highway but still a lot of them are also towing.
Plus if you don't mind I wouldn't mind seeing a few pictures of some big boats you towed behind your 2nd gen if you have any, I've seen one on this site look like by a motel.
Thanks again
Pssssssst his signature has info on his 2nd gen
Forgive me but how do I view it?
Right there on the bottom of his post... :duh:
2001 Dodge Ram, Cummins Turbo Diesel qdlb, 2500, 100hp Fireball injectors, Hamilton Big Stick Cam, Goerend 3 disc tc, 4 inch MBRP exhaust, FTE Resonator, Raptor 100, arp head studs, ats co-pilot, Quad xzt, j-hook, lots of gauges, lots of mag-hytec, bhaf, vulcan big line kit, Walker Engineering Air Sep, Over 1,000,000 miles on my 53 Block!!!! 2005 Dodge Ram, Cummins Turbo Diesel qdlb, 2500, dtt vb, dtt shift enhancer, billet bits 2006 Dodge Ram, Cummins Turbo Diesel qdlb, 3500
My suggestions and current mods are:
ISSPRO gauges: EGT, Trans Temp, Fuel Pressure, boost
Airdog 4G lift pump
Good batteries
Tim
Some how I don't see his signature, :shrug:. Maybe it's my phone, but man you really think.....I.... :doh: in fact I don't see anyone's sig :ahhh:.  I probably did something in settings.Screenshot_20180509-131217.png.258f49260f473521af6545a386975b08.png
Found my problem, for some reason my signature view was not turned on. Got her checked now.
