- Replies 52
- Views 16k
jr99cummins 19 posts
dripley 18 posts
Mopar1973Man 8 posts
Me78569 2 posts
With the turbo on the truck I assume?
I was going to ask the same question...
If an intake valve is open the air should trap in the cylinder. The only way to get to an open exhaust valve is if an intake valve is open which would be bigger problem. Now that's is on a stock engin
So I did a boost leak test and I get all the air back. Won’t past thru the engine. Took the turbo out and everything is fine. The trucks runs fine and starts without problems. No power or boost. Is fairly stock truck already change map sensor v44 and the injection pump. I’m checking the boost thru adrenaline quadzilla please help
