Heater exchange lines
- Replies 50
- Views 10.3k
mopar440cu 14 posts
Silverdodge 13 posts
Mopar1973Man 12 posts
trreed 5 posts
Ever since I got my 62/67/12 my egts went up to close to your numbers not quite, but the power increase in got... not way I'm going back ha ha
When u call me I'll explain cpp
Have any of you changed your metal heater exchange coolant lines that run under the exhaust manifold to make more room for the 3 piece exhaust manifold? See attached pic of where I am pointing to. The piping is really tight and close to it. I can only adjust it a little and the new turbo blanket will help with the heat to them. I was thinking of changing them somehow and was wondering if anyone has done this mod?
Thanks!!
Edited by mopar440cu
Better wording
