High Idle Delay Setting and Warm Up Mode Setting on the Quad
- Replies 15
- Views 9.6k
Mopar1973Man 6 posts
Jakez24v 3 posts
Me78569 2 posts
int3man 2 posts
Basically in a nutshell the delay is how long till the high idle starts. The temperature is the point in which high cancels. So I've got mine setup for 140*F and 60 seconds. If the engine is below 140
Can someone please explain what the High Idle Delay Setting is used for on the Quad and Warm Up Mode Setting. I am guessing the High Idle is used possibly to help volts for accessories?? I am also guessing the Warm Up Mode lets the truck warm up if its cold outside, but does this mean if I set it to say 195 degrees the truck can not be moved until it reaches this temp?
Trying to still figure this out. Thanks for any help getting me to understand this!
