Limited Pedal, VP problem?
- Replies 40
- Views 9.8k
dripley 14 posts
DIezl 9 posts
JAG1 6 posts
Mopar1973Man 4 posts
Now we know why the chicken crossed the road.
I spoke to @JAG1 yesterday. He's doing fine and busy building a new house for someone. He hasn't been able to post here for awhile due to, he thinks, a bad server with his internet provider. He and
Typically no because even if the APPS gets out of range it will throw a P0122 or P0123 code and dead pedal completely. This can be check by monitoring the TPS on a live data OBDII tool. L
I was having an intermittent problem where the truck ran great for the first 15 min then after that I was having problems.
It was acting like it wont spool up, ill hit the pedal and it will be around 10 psi of boost and will just sit maintaining speed for awhile until the RPM's hit around 2k where the turbo lights then takes off.
Tried resetting my APPS.
I have no codes on my scanner or check engine light.
I have about 17psi fuel pressure and doesn't drop much at wot maybe to 15psi.
I had a boost leak and fixed it then the truck ran perfectly for about 4 days. I was still skeptical if that was it and unfortunately i was right.
The last two days it has came back and has been way worse. So now it will surge I guess you could call it, I'll just be lightly accelerating and it will sort of cut out or stutter this has only happened twice. But now it hits a certain rpm and just hangs there no matter how much more you press on the pedal. If I let off from that position it acts normal but if i press anymore further it will not rev up any higher or do anything. It will still gain speed just very slowly. Feels like it has no power at all.
I measured my AC voltage today and got .028, and ill add i haven't had the TC unlocking/locking problem happen to me. The more i read into this AC leakage i was really thinking maybe it is the alternator but now that i tested it its looking more toward the VP.
The VP was replaced about 30k miles ago by a previous owner so its hard for me to believe its gone bad but i know people have had even less life out of these pumps. Its been fed good fuel pressure and 2 smoke oil while Ive had it at least.
Is it the electronics on the pump? Maybe from the edge comp heating it too much?
Can i check anything else or any other ideas?
Thanks
