2002 2nd gen dually performance recommendations
- Replies 15
- Views 4.1k
Daniel2ndgen2002 5 posts
Me78569 4 posts
oldbeek 2 posts
Dieselfuture 2 posts
Popular Days
I would recommend @Dynamic I never personally dealt with him, but he is a smart man from what I can tell and will do it right the first time. Few guys on here will second that. If I had automatic that
Is the tranny stock or have you modified it? A totally stock tranny will need some help to handle more power. That's the weak link. Your motor can handle fair amount of extra power just like it is. Yo
For that power level, I would run a Stage 3 transmission with either a Goerend 15SS or 17SS (or DPC equivalent) converter, depending upon what turbo you end up with. https://dynamictranspa
Hello there I have a 2002 2nd gen automatic 4x4 alt 5.9 24valve with 50k miles. I have lightly modified it. 5in Exh, bd exhaust manifold, s&b intake, Quadzilla tuner, air dog 165 4g fuel pump. I don’t want to get crazy with it but it needs more power to pull my trailer. I do want the best of the best. I’m wondering what you would recommend for brand and size injectors/turbo. Anything else recommended for better solid pulling power. Also after getting these things should I go ahead to do arp studs with new head gasket. If so what brand head gasket would be best or go back with a new oem head gasket? Please enlighten me cause there are so much to choose from.
Edited by Daniel2ndgen2002
