CTM (Central Timer Module) problem
- Replies 24
- Views 20.4k
wil440 11 posts
Chris O. 6 posts
dripley 3 posts
Mopar1973Man 2 posts
All good thanks to Chris. Replacement CTM arrived last week, was in the country the week before but customs are not known for rushing, 2 new batteries fitted to truck, CTM working perfectly, Chris ev
It would seem me and the JAG went to the same electrical school. The University of stick your tongue on the wire and see it its hot!! Though both of us have made a little progress beyond that.
I can get the central timer module and two new key fobs, then do the programming off the truck. eBay 56045202AA 1998 Dodge RAM 1500 Body Control Module Timing Alarm BCM CTM Amazon Car Key
Hi,
I'm in England and have a 98.5 24v 2500 4x4 It has a problem with the CTM, some plank had originally connected the drivers door lock wire the wrong way round so drivers unlocked, passengers locked and vises versa so put that right and noticed at the drivers door window switch someone had soldered resistors into the door lock wires ?? I have a 3500 5.9V8 of the same year so pulled the door panel off and checked it, no resistors so I removed them from the 2500, now both doors would only unlock so fitted both drivers and passenger switches from the 3500, it was still the same, I did notice that the passenger window motor now works from the drivers switch so proved I need a drivers doorlock window switch as it didn't work before, after checking the wiring diagram in the service manual I had both supplies out of both door switches, I then pulled the panel off below the steering column to check what CTM my trucks had, both have the High/Premium (same part number) so checked for door lock inputs at the CMT... all ok, checked outputs found only 1 giving 12v the other was giving 0v so I fitted the 3500 CTM into the 2500, door locks working when ignition is off, I'm going to have to swap it back into the 3500 to check operation (it's a while since I drove it and can't remember) but I need a CTM module, now here in the UK there is no way I can get it programmed to a fob as there are no dealers with the diagnostic equipment to program a module so I need a 56045202AA CTM module with original fob and a drivers door lock/window switch.
This has confused me all day and I'm a earthmover mechanic by trade, the problem here is people who have no clue on what they are doing messing with these trucks, any help or advice would be great
Neil
