6.7 water pump in 2nd gen 5.9
- Replies 7
- Views 2.1k
Popular Days
The increase in flow on the 6.7 pump is because of the cooled EGR. The 6.7 pump runs too much pressure on deleted trucks and it's not uncommon to see deleted 6.7's running 5.9 pumps, especially if the
I have 280k on my 02 it's running factory water pump. Truck runs at 190 in summer even with the clutch fan never kicking on. I'll put a 5.9 impellerd pump on if it ever needs replaced
I've not found a reason to even replace my OEM water pump after 350k miles. Still going strong. The biggest thing is coolant flushes, fresh thermostat and making sure the radiator face is clean.
Any body using the 6.7 water pump in their 5.9... if so see any improvements like when towing in mountains stays cooler longer before fan comes on? Any other pluses or minuses?
Thanks
