'The Boost Bus'
Recently made a purchase.  It is a 1996 E350 Club Wagon, complete with a forged rod 7.3L Power Stroke.  Buddy found this van on Craigslist for $1000 advertised as non-running, non driving, had a bad title, and no pictures.  But they guy responded.  So we headed to look at this thing, and found that it DID run, DID drive, DID have a clean title, and of course was nasty cause he was living out of it off and on (and it was $1000).  We talked the guy down to $600 and the Boost Bus was acquired.  Right now the rear seats and interior panels are completely stripped out, side doors don't work, only one rear door opens, and the lock cylinders in the front doors don't work so the lock is a padlock on the rear barn doors.
I want to lower it, put a tuner on it and take it down the drag strip at least once.  Eventually we want to put seats and a mini-bar in it.  Additional thoughts or ideas?
Of course, a $600 vehicle with 309k miles is not without issues.  Turbo needs a little help before any burnouts can take place. :(
Edited by trreed
  • Replies 38
  • Views 10k
  • Needs an intercooler as well.  But that'll be easy. Oh, and #firstmod is a Cummins sticker on the back window, to show how little we care.
  • It's the second diesel vehicle I've purchased out of Boulder... My pickup came from the north side of town.  This wonderful piece of engineering came from Pearl Street.  i'm surprised it was allowed t
  • I seem to remember a thread about the last burnout you did  .
Edited by trreed
100% agree with the drop/drag.
Did I hear you say hood stack or side exit exhaust??
Obviously the most obnoxious hater pipe I can fit!  You also might have heard 300/200's and a 467.7.....
Edited by trreed
Where am I when these deals come around? Good purchase. My 95 PSD was the most trouble free vehicle I have owned.
Bought it off a hippie in Boulder.  Always for sale, for cheap!
This is the first deal I've come across like this, and I didn't even find it.
Edited by trreed
:lmao:I was going to guess Nederland...but Boulder totally fits!
It's the second diesel vehicle I've purchased out of Boulder... My pickup came from the north side of town.  This wonderful piece of engineering came from Pearl Street.  i'm surprised it was allowed to be that close.
that's why the ad says it didn't drive.  They were scared to.
I wish that was the case!  Instead the guy said the "cam ignition sensor" was bad, so he towed it to a shop where they "had it running for over an hour" and then he parked it and never tried to drive it again.
Got the turbo off for inspection and prepared for a rebuild.... only to find someone has had their grubby mitts on it recently (no surprise).  The good news is the turbo looks like it was recently rebuilt, and everything came apart easily.  The bad news is they didn't replace it with the correct, 'more desirable' turbo. Stock OBS turbo has a 1.15 A/R exhaust housing.  Stock van turbo had a 1.0 A/R housing.  We found the 1.15 housing.  Oh well.  No idea on what went through the turbo.  My guess is the PO was trying to fix it on the cheap and a shop goes "well, we got this used turbo laying around", not mentioning the wheel damage.  Oh, and it's reverse rotation, and the oil feed is up from the bottom, so swapping to a S366 or some variant is more challenging.
Edited by trreed
How in the heck did it ever build boost if the compressor wheel was a reverse rotation?
Cause the turbine is reversed, the housings are reversed, everything is backwards.  It turns counterclockwise instead of what we're used to.
Edited by trreed
It happens.  I'm lucky as the guy who I split this van with is friends with a couple 7.3 owners (he himself has one, so I'm the only Cummins guy around 4-5 7.3's :( ) and therefore we have access to plenty of secondhand parts.  We probably are gonna mess with the HPOP since the turbo is out anyways, to get *just that much more* flow to the injectors.  Maybe then it'll do a burnout!
Edited by trreed
I seem to remember a thread about the last burnout you did :think: :whistle:.
