99 Cummins low boost lack of power
- Replies 9
- Views 8.8k
Evan 3 posts
Mopar1973Man 2 posts
wil440 2 posts
Dieselfuture 1 post
Injectors always are sooted on the tips and clear tracks will be seen across the tips away from each hole, you have a problem if there isn't a clearish track away from each hole as thats a blocked hol
Never seen ash on injector like that but then again no one here adds oil of any kind to diesel. I think its rather odd that these trucks were designed and built in the usa and thats the major market b
Recently I installed gauges in my truck with the suspicion that it had a low boost issue. After installing the gauge I have a peak of 16psi with my xzt+ module turned on. From the research I gathered it should be a minimum of 22 psi+.
Last year I performed a leak test and didn’t discover any boost leaks, but I plan performing another test to make sure. The truck overall just doesn’t have the power it should. It never smokes, and the check engine light has come on in the past for a crank position sensor, but is off now. Just looking for suggestions on the low boost issue and lack of power.
I was curious if the waste gate might be open, but figuring it does build boost maybe not? Any help is appreciated.
