- Replies 18
- Views 11.1k
KATOOM 6 posts
015point9 3 posts
trreed 3 posts
Mopar1973Man 2 posts
Popular Days
IF you need friction modifier, 10 oz of Ford friction modifier is what you want. It seems to act the best. None for the front as it is not a LSD.
You can also decode here but I'm not sure it gives all the specific package component details. Usually there's three methods to identify a LS differential: 1) There should be a sticke
Dodge guy told me I've might what was called "corp axle". And if I understand him right, Chrysler used Dana housing, but had Dana dummy down their product. Guy said the "M" might be "M" as in Modif
So I came across a web link with some great information. I’ll leave a link below. This website tells you all about maintenance intervals and fluid amounts etc. I plan to change my diff gear fluid soon and I plan to use Scaeffers 75w140 gear oil. Iv heard talk about adding a friction modifier? I’m curious if anyone knows about this stuff and how much is needed per axle? http://www.cumminshub.com/5.9-24v-cummins-maintenance-schedule.html
Edited by Marcus2000monster
