Kinda No Start Condition (Broke Down 4 months)
- Replies 25
- Views 6.4k
livewire 7 posts
Mopar1973Man 6 posts
dripley 4 posts
JAG1 3 posts
I've been using 5-20% biodiesel it seems more and more stores sell it around here without adding anything and if I find a station where it's not marked and no one knows what it is I'll add the two cyc
Try running cold water over vp44 when it does and see if it helps.
I ran some diesel 13, 14 years ago and never noticed any diferences. They did not have whatever that slick diesel lubricator is back then, IIRC. It does have cetane booster in it which will dry the fu
Going to try to put all the information into the first post so it will all be in here:
Truck - 2001 Dodge Ram 2500 extended cab, 5.9L Cummins, 113,000 miles (Barn Find)
I have had this truck since 78,000 miles, driving it two years now.
About 3 months before I bought the truck lift pump was not working and the guy (that found it in a barn) kept driving it around with a hard start condition for about a month before putting on an Airdog on the frame. He owned the truck for 3 months.
I buy the truck, runs great for a year and starts having a dead pedal issue. It was throwing codes for TPPS and the P0216 code. Replaced TPPS with a timbo unit. Problem was good for about two months and then came back with a vengeance and made truck almost undriveable during a warm day, cool or cold day, dead pedal 1 or 2 times.
Broke down and bought a Injection pump (IP) from Thoroughbred Diesel (TB Diesel) and installed it, ran better than ever for 6 weeks and then one day while coming thru Knoxville Tn, hauling a car on a trailer, it just died in 6 lanes of traffic. Long story short, I got it home and started diving in, truck was not throwing any codes, first thing I did was bought a FASS fuel stem and draw straw and installed it because the Airdog was working but making a really bad sound (beer can in dryer) and I wanted the filtration system of the FASS as well. I was not getting any fuel thru the injectors, 1 and 4 would push out some foamy fuel but nothing with any kind of pressure. The truck would startup sometimes when cold,and run for 5 -10 min and then shut down never to start again that day.
After I determined that I was getting good fuel to the injection pump, I looked into the IP, talked to TB Diesel and troubleshot some stuff with them and they agreed the pump had failed. Took it off and shipped it back, they tested it 2 times and said it passed with flying colors. They sent the pump back and I installed it, opened up all the injectors but #2 and bled the air out and trucked fired up like a champion, truck ran for 45 minutes while I was reinstalling bed from where I had installed the draw straw. I shut off the truck for 15 min to install two bolts near exhaust, truck never started again. But did throw a DTC Code P1689.
Talked to TB again, and they rented me a Breakout/test box to run on the IP to see if it was the problem, as long as the box was hooked up the truck would start great and as many times as you wanted, messed around with it for 2 days trying to get it to overheat and shutdown as before, no hiccups at all, ran for over 2 hours on test box, but the high idle button on the test box would kill it if you pressed it. TB didn't think that was a problem and recommended I look into a short in wiring/ECM now that the P1689 code was present.
Tested out the injection control circuit using a couple of posts on here about the P1689 code, sent the ECM off to be tested they confirmed it was faulty and sent it back, finally gave in and ordered a new ECM and installed it yesterday, it was a plug and play unit and the truck started up the first time great, I shut it off after running for 15 minutes, started back up, but had a little bit of hesitation. It threw on some check engine lights and when I went to check the DTC's with my smarty, it said ECM Changed and had a P1694 code, smarty was still VIN locked to old ECM. I reinstalled my old ecm/core this morning restored the ecm and pcm to stock (unlocked the Smarty from the truck) and then reinstalled the new ECM and trucked had a hard start condition but finally fired up. Ran it for about thirty minutes with air on, accelerated nicely, it would rev up to 3000 rpm no problem, went to test drive the truck, as soon as I took it out of park went dead, will not even offer to start back. No DTCs, I checked fuel at the injectors #1 and #4 pushing out foamy fuel again, nothing out of #3 no pressure. Lift pump is maintaining 12-14 psi when it sits idling.
I have went over the wiring on this truck, checked every ground I can find, test lighted the IP plug, checked bottom of fuse box for corrosion, swapped out relays, Batteries were installed new about 6 months ago but had both of them tested, check my battery cable ends. I am at the end of my rope, i suspect a short in harness, but how do I find it? I did unhook the batteries each time before working on any electrical connection.
Any help would be great, one guy asked me if my Brake lights worked???? I have not verified that but I have checked numerous grounds, I found one unhooked on under the brake controller, but it appears to have never been attached to anything. it was coiled up and wire tied together.
Please Help??
Edited by livewire
