Looking for Staff Members
So having owned my ‘99 for a little over two months and towing my tractor a few times I think I have decided to see if I can upgrade some things to get some more power.  I am as I think that would satisfy my needs.
Looking at 7X.009 SAC injectors, a turbo, gauges, and a tuner of some kind to manage smoke and heat.
Need some recommendations on a turbo and tuner.
 Thinking about this Turbo as a direct replacement.
For the tuner:  either an Edge Comp or the Quadzilla Iquad.  Really don’t have the experience to create my own tunes and need more knowledge of diesel theory to be able to get the most out of a tuner so leaning towards something with “canned” tunes.
Will run gauges for egt, boost, and trans temp.   What range boost gauge should I use, up to 50psi?  Already have a fuel gauge.
So chime in guys with your ideas and help me choose the right parts to start with.
  • Replies 78
  • Views 16.5k
  • dieselautopower
    dieselautopower
    no need to do anything with the injectors.     309 is the pop off pressure.   You will like the extra power!
  • dieselautopower
    dieselautopower
    HX35 can have either option below 5 bolt hx35  https://www.dieselautopower.com/s200gx-e-dodge-ram-upgrade-turbo-12769880001 picture #2   hy35 is same as this https://www.dieselautopower
  • Your Super B will get you to your desired power range, when coupled with the Adrenaline and 7 x 0.009 injectors or larger.
On 9/18/2018 at 4:43 PM, Me78569 said:
yes
7 x .010's are a well rounded injector for really any setup under 550 hp
I did some trading with a friend and have his 7 x .011's. They are DAP injectors. Supposedly only have about 1500 miles on them. But I am sending them to Jacob for testing and rebuild to be on the safe side. But should I have 7 x .010 nozzles installed, or will the 7 x .011's be manageable for under 550 hp?
Not really with an edge ez. You’ll over fuel the HX in a heartbeat
Oh definitely not with an edge ez. Sorry I should have clarified. I'm just planning ahead. I have the quad on the shelf loaded with v2 tuning.
My 7x10 are virtually smoke free with my current tune, and going down in tire size helped too. 7x11 should be pretty close, but if you still have hx35 it may get fun tunning. But should be ok, just need to detune it more.
Ok, Turbo will eventually be upgraded.
  • 4 weeks later...
So I’m new to all this performance. I want to hit the 400 to 450hp mark. I was told the stock injectors would get me there is this correct information? Waiting on a shop to get there dyno setup so I can see what I have know.
Even if you could I don't think it will be a good horsepower. Be way better with bigger injectors Quadzilla tuner and a good Turbo. Jmo
Kind of like I'm in that range with +75 HP Injectors (7 x 0.0085) and HX35/40 hybrid (60/60/12) and Quadzilla.
Stock injectors will not get you there.  Neither will  a stock turbo.  325-350HP is about as much as you can hope for with a programmer (ADRENALINE!!!!)  and stock turbo/injectors.  Your truck will likely make 400-450Hp with a set of 100HP injectors and a super B turbo.  Its a great responsive set up.  Consider doing 150HP injectors and custom tune the quadzilla.... then if you ever decide to go with a 62mm turbo you can hit 500HP with the quadzilla turned up.
.....(shameless plug for quadzilla and injector combo with discount) https://www.dieselautopower.com/dap-vp-truck-performance-bundle
Edited by dieselautopower
@Cummins4life Can't go wrong with DAP. Great company.
Quad and 150s. Having a set injectors rebuilt with 150 nozzles by DAP right now.
So with the turbo I have now which is the super b sx s358 turbo won’t work? it’s putting out 44lbs with out adjusting the waste gate  it the way it came from bd. I also have the the quad  adrenaline IQuad with the v2 already. And k&n cone filter already
So I pretty much need injectors is there any other mods that would need to be done. To support 450hp?
If your signature is up to date then you should be just fine.  You will be pushing the upper limits of the clutch rating, but South Bend usually under rates their clutches
Yeah it’s up to date. The tranny and clutch I’ll upgraded when it’s broke that’s only the wife will let me spend a large amount. Plus if it’s not broke don’t fix it haha
i was new to the world of diesel pickup trucks a few years ago.
First truck, 2004 3500 2wd, crew cab, 8 ft bed dullie with a Cummins and a 48RE Automatic Transmission and an Edge Juice  w/ attitude, 147,000 miles, huge air bags, 4 link rear end.
lots of power, hauled heavy loads with ease @ 20+ mpg. I loved that truck until the transmission went out. I looked into the cause of failure, Dodge has put off designing an automatic transmission to handle the big 6.
You want to modify the engine for higher output, you will have transmission trouble using the obsolete 48 or 47 trans, which by the way is a 727 torqflite from the 1950s gone thru several reversions/bandaids to keep production costs to a minimum.
the Edge Pro Comp is for Racing Applications.not recommended for towing.
I suggest doing your do dillagence in bullet proofing the running gear.
so you can add a bunch of reliable power.
As far as I know the Cummins is a million mile motor providing you take certain proactive precautions to address inherent design flaws I.e.
 Killer Dowel Pin
 53 block castings is of major concern
 lift pump to safeguard the injector pump.
 auto trans
I suggest you study up on the auto trans and how to best handle the additional power you want to add. I replaced my truck for one with a six speed manual.
verify you don’t have a 53/block
verify the killer dowel pin issue has been addressed.
if you have a stock lift pump replace it to safeguard the fuel injector pump
monitor/defuel all critical drive train parameters
Old time 18 wheel operators would tell you don’t go down a grade any faster than you went up it, I suggest an exhaust brake and a way to add holding pressure to the Auto Trans when towing, hammering the throttle, going down hill.
I agree above, but i would also point out that unless you increase your line pressures an exgine brake will not help you much. Make sure you have the line pressures adjusated so that your braking power from the exhaust brake is making its way into the transmission.
