- Replies 13
- Views 2.4k
Jack Owen 5 posts
Haggar 2 posts
dripley 1 post
Dieselfuture 1 post
Popular Days
Its probably because the silencer ring is still in that turbo. Kidding but I've yet to see one of those oil coolers fail personally. I have sold plenty of those gaskets though. In fact I have a p
I don't think that's suppose to be there. That may be a hole in an oil galley. It's under higher pressure when the engine is running than the coolant pressure so it pumped the cooling system full of
Oil gallery plug should be there. I am betting it will become apparent when you get it cleaned up. Looking for more pictures,but look at this one (I circled it in red). I just don't know if it wa
Radiator filled with engine oil...FAST! Took about 15 minutes to empty half my pan. Ran just fine. NO LEAKS in the oil cooler. Could an oil cooler gasket fail enough to allow that much oil into the water jacket?
