I installed a new set of injectors and bled the lines.  It'll fire up.  Running rough though.
When I hit the gas pedal I get zero.
Check engine light is on
3 key turn read offers me these clues.
PCU
P0122 + P1693
ECU
P0222 + P1693
PCU
P0122 + P1693
ECU
P0222 + P1693
Update got the throttle back, fixed itself, let it idol and now it seems to be running smooth.
Error codes still in play.
  • Replies 55
  • Views 6.4k
  • I would clear the codes and see if they come back. Then chase them.
  • I upgraded from stock to Bosch RV 275
    The problem is the Edge EZ fuel map is design around only the stock injector. So now that you step up ot the RV275 there is no way to remap the fuel curve versus boost to control the smoke. This why p
54 minutes ago, leety said:
The one I have is old and super primitive.
I'm using the Edge EZ  with the jumper set on #2 and RV275 injectors with zero smoke problems.   I tow an 8,000lb 5th wheel and I don't want to overwhelm the almost stock 47RE transmission with more power.
Good to know :-)
There is most likely a gear and tire difference between @IBMobile and @leety . I know Ibmobile is 4.10 gears with 245's. But I'm not sure what Leety is running. This will make a difference for smoke.
Help me out here.  What's all this about 4.10 gears and 245's?  Please translate to noobie for me.
My axle ratio is 4:10 (4.1 turns of the drive shaft to 1 turn of the axle) and my tire size is 245/75R-16  giving me a final ratio of 4:22 which translates into a little higher RPM at cruising speed and a lot of pulling power.
Basically, with Ibmobile he's got 30" tires (245/75 R16) and 4.10 gear ratio in both front and rear axles the means it takes less fuel to get rolling and spools the turbo faster so smoke is not an issue. Basically the 245's tires change the 4.10 gears into 4.26 gears making more torque for the tires.
Now with 265/75 R16 tires and 3.55 gears in the axles, your much taller gear and takes much more fuel to launch and spool so smoke is now more common place. Now with 265/75 R16 tires and the 3.55 gears is factory SLT package. So you are 3.55 final to the ground. Now if your tires are larger the ratio number goes lower so by the time you reach 37" tires your final ratio is 3.00 to 1. This makes the truck struggle and smoke is typically way worse.
Optimal is about 3.73 to 1 to the ground. Basically 245's tires and 3.55 gears.
Ok I'm starting to see what this is all about.
My axle ratio is 3.54 my tire size is 245/70R19.5
Final ratio to the ground is 3.39 to 1. So your very tall geared...
So does the manual transmission help me any?  Or is smoke and funny faces from the restless CA natives just a thing I will have to deal with?
Edited by leety
4 choices...
1. Deal with the ugly faces and pissed off people and possible smog violation.
2. Change out the wheels and tires to correct your final ratio.
3. Spend the big money on getting the gears changed in both front and rear axles. (about $4,000)
4. Change from the Edge to Quadzilla and add some lag to your daily fuel map to control smoke,
1 minute ago, Mopar1973Man said:
4 choices...
A ha!  Well answered!
Well it's big a** truck so #1 is inevitable, with or without the smoke LOL
I think I'll start with 4 sounds like a good overall thing to do anyways.
Would the lower RMP at high speed improve my gas mileage or is this one of those times I should take my glass-half-full, rose colored glasses off?
Can you recommend a Quadzilla model?
Easy to answer if your normal highway speed is 65 MPH then 3.73 final ratio would be optimal. This would put your at a perfect 2,000 RPM's at 66 MPH. This has just been pushing my MPG just over 21 MPG just before I parked for the head gasket.
Quadzilla Adrenaline
Nice MPH.
Before the new injectors going about 68 MPH faster in NM, with 1800# of Bigfoot camper in the bed I'm getting about 15-16 MPH.  I'm hoping the new injectors improve that a bit.  I'm guessing the Quadzilla would also help.
A bit of tweaking to the timing making a small retarded area to get spool up faster and the jump into advancement but keep it down around 19* total at cruise. This will help a bunch with launching smoke and EGT control too. Then fuel map start out about 90% and work your way up 1% per 1 PSI of boost then after 10 PSI than you can step up 2% per PSI.
Sounds like fun!!!  I'll have to take a class to figure out how to program it to make all that happen.
For now I'll have to work with what I have and keep my foot out of it when I know the smoke will blow.  It's reasonably predictable.
For sure sounds like I will want to upgrade tho the Quadzilla Adrenaline to get it as good as it can get with the setup I have now.  No matter what tires or gearing I mess with later I would think the Quad is a thing to have.
I may just pull the old stone-age Edge EZ out and see how it goes in the native environment.
You'll still find some smoke on the stock tuning because the Dodge ECM is calibrated for the smaller nozzles yet.  Best advice is to not get on the skinny pedal when your under the turbo.  That will cause the most smoke.  Wait until the turbo is spooled to get on it.
As for Quadzilla University:
Unfortunately, as @Me78569 says, the video is flipped.  Unsure if he's got a fix for it. But this is the basics for the V2 tuning.
Nope I sure dont and I doubt I will redo it as it takes more time that I have free right now.
Do I have to stand on my head and look in a mirror to tune with it? That might be a drawback.
I swear it used to be right side up.  That Colorado air now affects YouTube apparently
