Gutting cab/removing wires. 2000 Ram 2500 cummins
- Replies 21
- Views 7.4k
Dieselfuture 6 posts
Chris O. 4 posts
Mopar1973Man 3 posts
pepsi71ocean 3 posts
Yes i am. Been dwelling on it for a while to dedicate it to the track. Finally popped the HG so now shes getting a huge makeover and lots of goodies. Sitting at 600/1200 right now without the upgrad
2nd Gen Dodge Ram Cummins 24 valve minimum computer list required: ECM, PCM, ABS (CAB - Controller Antilock Brake), Electro-Mechanical Instrument Cluster (EMIC). At least one electronic c
The CTM does dome lights as well i believe. Now they're calling them body control modules which basically means that anything you do to the "body" goes through that module. The CTM was the early versi
Vp44 guys. Im doing alot of work on my truck, cutting weight etc...my plan is to completely gut the cab, pull everything out and leave just the column, seats, shifter, and guages...gonna use my tablet/quadzilla for tach and speedo.
My question is, Is there anything in the cab that is a "must have" to complete circuits or anything that if removed would cause the truck not to run? Besides the obvious **** like ignition wires. Id also be open to wiring a push button start. Any info would be much appreciated.
