VP44 testing
Is there a way to test VP44 health when there is no codes? My truck ran like crap this morning. Very chattery and doggy. I’m wondering if my VP isn’t going south. It started pretty well but was pretty chattery for only 25 degrees. Scanned for codes and got nothing.
  • Replies 53
  • Views 10.3k
  • Marcus2000monster
    Marcus2000monster
    That when I wish I had a car! I’m the same way. I started my truck when it was -30 and almost wet myself but I couldn’t cuz it was so cold. But she never failed to start this past winter.
    No. The only way to test a VP44 is have it sent in and ran 3 hours on the test stand which come typically at the cost of about half a VP44 replacement. (400 to 500 dollars)     Typica
  • yep please show us the issue we will make it right.
A BHAF muffler. Who da thunk. Is the end inside the filter open?
Yes, the end of the perforated pipe is open and the opening is located about 2 inches from the inside of the blank end wall of the air filter.  This project is one of the many small things that I have done to incrementally make the engine quieter.
- John
11 hours ago, Tractorman said:
I made my own silencer for the BHAF and now the BHAF is much quieter inside and outside of the cab than the factory air filter box and filter.  I used a ribbed 3" perforated plastic drain pipe as the silencer.  I modified a piece of my son-in-law's exhaust pipe from an '06 truck to make an airtight connection.  I sealed the plastic pipe inside  the modified exhaust pipe piece.
The turbo whistle is completely gone now (the one sound I liked) and the exhaust brake is much quieter now. It is amazing how much sound is generated from the intake side of the engine.
- John
@Tractorman What would happen if a guy just threw a piece of that drain pipe inside and replaced the intake hose? Might need some sort of way to hold it in as the turbo might get some idea to suck it into the compressor.
Edited by Marcus2000monster
11 hours ago, Marcus2000monster said:
Just get a G8! Lol they are really nice cars
Actually had a 2009 G8 GXP 6 speed manual for a bit. It was an expensive horse to keep in the stable and sucked in icy / snowy conditions so I sold it.
The G6 we have now is pretty nice and has plenty of giddy up when the transmission works.
9 hours ago, Marcus2000monster said:
I wouldn’t mind a run down of Ford vs Cummins. Not that I have anything against any other engine but out of curiosity. I work on 7.3s, 6.0s, 6.4s, and 6.7s every day and its rather obvious that they require more $$$ and maintenance than any other Cummins diesel around including common rails.
Poor guy... Stuck working on Powerstroke engines everyday. 7.3 and 6.0 are cake. I absolutely hate working on the 6.4 and 6.7 engines. Has Ford figured out better fuel / water separation to keep the fuel system from rusting on the 6.7? I've done at least 5 fuel systems on the 6.7 engines in the past year because of rust in the high pressure fuel rails and injectors.
6.6 Duramax engines are in the same category as the Ford 6.4 and 6.7.
I didn’t know they made a 6 speed in the G8s was it a GT with the V8 LS motor? If not then they're is a world of difference. The GT is extremely powerful.
I have not  done much work work on the 6.7L Powerstroke. Mainly 6.0 and 7.3. They’re pieces of trash. All of them but the new 6.7 and they have a lot of problems as well.
The GXP trim was the top of line for the G8. It has LS3 6.2L V8 that was said to have 415 horses under the hood. I'm not sure how many had manual transmissions but it was sure fun to drive.
When we're fixing Ford's we can always look the huge emblem in the grille and say at least they circled the problem for us and get a chuckle.
Lol good one!
6 hours ago, trreed said:
. If a 7.3 won’t start, it’s the cam position sensor 99% of the time
Or the glorious glow plug relay in the winter. I learned quick to keep one in the tool box. 14 years and 165k I never had a cam sensor issue on mine. Lucky I guess.
I guess so! Glow plug control modules are a common issue as well.
Muffler for intake. Very original, cool idea.
