- Replies 37
- Views 6.9k
Dieselfuture 15 posts
NIsaacs 6 posts
dripley 5 posts
Mopar1973Man 3 posts
So far I like these tires, snowing here in quad cities and in 4x4 no problems at all 2 wheel I can get going but need to spin them a bit, but can still go in about 10" of snow in 2wd. I can finally sp
I have the Hankook dynapros and I really like them. I have roughly 30k on them so far, they have worn very well. I rotate every oil change and have white letters out. You will like them, certainly not
Replaced the junky Mastercraft tires today with Hercules Terra Trac AT II's in the same size, 285/75x16E. Only 22K miles on the old ones, rated for 50K. I did get some prorated tread wear credit out o
I'm looking to get new tires and thanks to @Mopar1973Man and few other reviews I'm thinking about getting these Hankook ATm in 265/70/17 E rated.
Currently I have Toyo Open Country at2 in 285/70/17 and they are OK tire, but not as good as its hyped up. I had one crack in between tread on me in a first month of ownership, but it's been 4 years now and the crack hasn't grown. I put same set on my work truck f350 (265/70/17) and they are almost gone after 25k, and have some tiny cracks all over them, like they are 10 years old.
What made me lean this direction to go smaller is few things. One is I got a used set of rims and tires of 03 with some junky 265/70/17 BF Rugget Trail but right of way gained 2mpg speedo accounted for, and two easier steering and take offs in 2nd gear and just less load going down the road.
After having these used 265s on the truck I'm starting to get used to smaller look, but still looks better then 245
I just can't climb over that hump to put 245s on
Anyway part of this post is to say thanks for convincing me to a smaller size and Hankook brand and the other part is I was going to see what everyone else runs for size/brand and how you like it. Maybe overall mpgs to compare tire size vs gear ratio vs everything else. I think we'll see a bigger picture that way.
Also what sites do you use to get tires, so far I've looked at tirerack, tirebuyer, and (tire-easy.com which seems to be cheapest but have no experience with them.)
Another thing I want to mention is these Hankook being a China tires are not much cheaper in this size and rating, I was expecting it to be in $500 range for a set of 4. They must be getting popular enough now that prices went up
So let's hear your thoughts
