Precautionary travel items.
I’m looking for a list of items to keep in my truck on long trips and trips into remote backcountry. I can think of a few things off my head but like a detailed list of things that can keep my truck on the road if necessary.
  • Replies 32
  • Views 6.3k
  • In 1973 I had a Volvo blow an engine in Greenwood, Delaware.  I got it over to my grandfathers processing plant's work shop where I was able to install a used engine that I acquired in Seekonk, Massac
  • I carry a rubber chicken for fun. It is not edible or chokeable for those that might inquire.
  • While I agree with @Mopar1973Man about most failures not being able to be fixed in a remote spot I do carry a few simple things that will alleviate some more common issues.    In my truck bo
I carry a assortment of hand tools, a spare serpentine belt but no real spare parts. If I carried any something else would break. Might carry a spare lift pump if I can get the failed one working. But I dont see the back country in mine.
Thanks man! Don’t you carry a spare chicken in case you get hungry? Lol. I have a serpentine belt on my list along with a small toolset including a 3/4 end wrench for cracking injectors in case I run out of fuel.
Never carry any tools or parts. No sense in it. Every time something has happened to me in the backcountry there isn't a tool that will fix it. Like for example breaking the main shaft of the transmission. Unit bearing failed. None of this stuff can be fixed along the road. What I do pack is everything to ensure my own survival.
  • 2 MRE's (Meals Ready to Eat)
  • 2 half gallon jugs of water
  • Extra jacket
  • Gloves to keep my hands warm
  • Cigarette lighter and matches
  • First aid kit
  • Mutli-tool
  • Poncho or tarp
  • GPS
  • Flashlight & batteries
So when this happens...
Image result for mopar1973man mainshaft
You know the list above will keep you alive till you can get to safety. It wont do you any good to have a bunch of heavy tools if the part that failed you don't have. Like I said before whatever fails typically you don't have the tools or the means for repairing in the backcountry. Now the truck is dead and not moving can you ensure your survival?
Personally I think there is a big difference bewteen long trips and remote trips.
Remote trips...think more survival as in water and food and keeping warm.
Long trips...2 credit cards, fsm in your phone.
Back to remote.  Nobody's going to bail you out except yourself.  We have 4 day food supply under back seat and usually carry two 3 gallon water jugs.
(I think @Mopar1973Man  and I hit send button same time.)
Anyway also depends your understanding of "remote"
Edited by 015point9
Info
  • Extra jacket
  • First aid kit
  • Mutli-tool
  • Poncho or tarp
  • GPS
You know the list above will keep you alive till you can get to safety. It wont do you any good to have a bunch of heavy tools if the part that failed you don't have. Like I said before whatever fails typically you don't have the tools or the means for repairing in the backcountry. Now the truck is dead and no moving can you ensure your survival?
I agree with you gentlemen. I plan to carry all of the above. I’m thinking maybe a spare Carter fuel pump, serpentine belt, and I always carry extra engine oil. Also have a Haynes repair manual.
LOL... You would be stuck. Even traveling through my home area there is no cellservice for over a 100 mile span of the canyon. Ask @IBMobile he learned really quick even though he was right on US95 and just north of Riggins, ID by 8 miles there was no cell service to get help with. Like the New meadows tower only has service for about 12 miles total and it gone.
As for @IBMobile he lost his VP44 pump north of Riggins, ID leaving him dead on the pavement. No cell service and had to get a ride to Riggins by a passing deputy.
Agreed Mike. Woodcutting yesterday in the mountains and had zero cell service. Satellite phone is the only option I believe.
I
I just wait for one of your fine law enforcement types and have them call.
Does anyone have a recommendation for a pro set of jumper cables?
Jumper cables only work if there is a second vehicle. If there is a second vehicle your rescued. I typically have a cheapy set in the bed for the winter time. I've never need a jump start but I've given plenty to others.
You could be waiting a very long time. Like Idaho country no longer comes to Riggins much anymore. The Adams country rarely goes north towards my place one in a blue moon. Hoping for a deputy to bail you out is not a good answer. With budget cuts in both country patrolling is no one of the highlights any longer.
3 minutes ago, Royal Squire said:
Haynes manual may be better than nothing, but just barely. IMO
Fire starters to go along with the matches. :lmao:
After you get spare carter pump practice putting it on just to make sure.  I carry one so that I'm not subjected to the mechanic where I break down at.  Not to mention good insurance, now my regular pump won't ever break:thumb1:
Here we are worrying about lift pumps. :rolleyes:
I look at this way the truck fails for whatever reason. I'm better of getting to services then placing a phone call for tow or repair. At the point of failure, I see my truck as one thing shelter. If the weather is poor at least the cold wind is not blowing on you or being soaked by downpour rains or snow storm. If you got food and water and possibly a blanket you'll be able to relax and wait the storm out. Even if its just a simple flat tire. There is no need to get out and get soaking wet.
Yeah, you can carry a spare belt if you want. I quit doing that because in 356k miles I've broken ZERO fan belts. I don't bother with the spare lift pump idea anymore. In 13 years of service, I've never lost a lift pump on the road. Typically those give warning like my AirDog was loud and pressures were dropping over a solid week. I knew it was dying. I do carry fuses. That a simple fix but if it blows twice do NOT insert the 3rd one. There is something wrong! Like my trailer blew the trailer fuse. then blew the second one. Yeap. The tail light shorted out and MELTED everything! Again even though some of these things appear like they can be fixed in the field are typically wind up not being to repair because you need another part. Just like my lasted I hitched up my RV in Parma, ID and dome light went out and the power mirrors quit. Wasn't a fuse problem and couldn't be fixed in the field.
This is why I don't bother with a ton of tools (which I carry one socket set that's it!). I will not carry spare parts like belts because by the time a year goes by the belt is total beat up and worthless and still never used.
With all the good people in idaho someone would stop and offer help.  (Even if their idea of help was offering the their "only dodge" tool they have.  Which was a pair of gloves so my hands dont get cold pushing on the tailgate.  Wasn't to funny.  Happened south of Owyhee area near jarbridge and duck valley  years ago.
Another good example I was heading out to get firewood for the day with a friend and took the 1996 Dodge 1500. Got back up in the Nezperce Forest about 15 miles from town and the truck simply just died. I had tools with me again a socket set. After all my simple testing looking for fuel in the injector rail, and spark at the spark plugs I realize my PCM was fried. Not a single thing I could do but turn the truck around which we did. We managed to get the truck turn around and got a free downhill ride which put us near a ranch house to make a phone call and get a tow truck to pick up. Again there wasn't a single thing my socket set could of fixed. I needed a PCM... So I had the tools to pull the old one off but that would of been a week to wait for the new one to come. Better off towing to safety.
I carry a small tarp so I can slide under the truck easily, a spare lift pump which I needed to change 35 miles from home only once so far, a better bottle jack than the factory, a torque wrench for checking wheel torque on aluminum wheels. Cash for more versatility, and a new idler pulley and belt with the tools to change it out. Last, but not Least, Mopar1973Man's phone number. :lol:
Mopar1973Man, a couple flares be good on that mtn road you drive.... comin around the curve on snow they may not see you on time boss.
I didnt worry about anything in mine till I reached up about $3,000 in new lift pump,  Towing , car rental and lousy mechanic.  Now armed with this cite. Fsm in phone and lap top.  And learned about a few things about our trucks.  Before I got ripped off my thinking was why learn, these trucks as hardly ever break down so why take the time to learn about them?  So today everything I need for full timing in RV.  Few tools, rv supplies, wood working stuff, jewelry making stuff.  Now if wife would get better medically, I would be where t-stat on rv heater doesn't come on.
I'll give you all a clue. Most all failures give clues in performance like MPG record dropping out. Like my VP44 was dropping MPG well before the pump died. Most other failures show up as heat. EGT's higher than normal, coolant temperature higher than normal or transmission temperature higher than normal.
