- Replies 78
- Views 15k
mossyoak71 23 posts
pepsi71ocean 14 posts
Mopar1973Man 10 posts
Dieselfuture 8 posts
A couple of thing 1. I hear no audible difference at idle between the 300 bar and the 350 bar. I ran these back to back. 350 bar should be ~5* of timing difference. There is a VERY audi
Which is why they are clean as ever, and this truck idles so smoooooooooooooth.
HATS OFF TO DAP!!!!!! I just got home and my injectors were delivered. According to the paperwork, 4 of the 6 wouldn't even pop. The 2 that did were in the 270 range. They cleaned and installed 6
The info in my signature is up to date, with that in mind, I have an issue with the engine stumbling. No matter if I'm in the 0 setting or 3 setting it will stumble on acceleration from around 55 mph. When if you slam the throttle. In the stock setting it doesn't do it as bad. Feels like a miss. Now if I place the quad in 4 or 5, it will stumble until it kicks the wire tap in and then you can feel the miss ever so slightly. There are no codes, I have changed out the injector lines all 6 and torqued them down 28lbft. I was thinking it was the old lines, maybe they were just over torqued, no luck. This issue is really prevalent when towing. Now with no codes, could it still be the VP? Also I have noticed that my pressure gauge that I have hooked to the fass is bouncing. Still holding 20psi at the fuel pump, but pulsing. Just confused on where to go. Don't want to start throwing money at it. The VP is 14 months old and has 45k miles on it now. Any advice appreciated, thanks in advance.
