- Replies 7
- Views 4.2k
AH64ID 1 post
Hawkez 1 post
Tractorman 1 post
ofelas 1 post
Popular Days
Sounds like it's stuck open. By rubber ring do you mean a gasket? They should all have one. Lots of horror stories with non-Cummins thermostats. I'd replace it with one made
It might be worth the time to inspect the new thermostat without removing it. If that rubber has separated, then coolant would be bypassing the thermostat at a low rate and it could match your sympto
This week I installed a new heater core and with that I flushed the radiator, installed a new thermostat and radiator cap. I pulled the radiator while I had it empty to inspect it for blockages and it looks great. Before I took it apart it was starting to run a little warmer then usual especially when under a heavy load, but it never overheated.. I had suspected that the thermostat was going bad. I put 50 miles on it after flushing it and changing those parts and the temp held steady and nothing was out of the norm. Until I drove home last night. On the freeway the temp sat at around 160*. That is after it warmed up to just above 190*, then it dropped down and sat there steady. If I got on the accelerator it would rise to 190*. Maybe I got a bad thermostat? It is a 190* thermostat from Napa. I'm not sure what else would cause this, would air in the system be the cause? I've never had a car or truck run cool like this. The outside temp was 50*, so nothing strange.
The thermostat that I put in had a rubber ring that sat around the thermostat, the old one didn't have anything like that...
