96’ Ram interior falling apart.
- Replies 15
- Views 3.6k
dripley 4 posts
Blueox01 3 posts
The_Hammer 3 posts
Sycostang67 3 posts
Look on Craigslist for 2nd gen trucks being parted out. I have seen quite a few in there before. You will get lucky. Some of my real nice finds meant waiting and searching for over a year.
I found a good dash core a local u-pull-it, because mine was all cracked, I got a whole new (to me) agate interior for under $100 (old interior was LT/Gray) I did buy a new Dash cover from LMC truck.
I’m not sure what I’m going to do yet. Ideally I want a permanent fix and I think that’s going to require a lot of custom work.
I am completely disgusted with the interior in my 96’ Ram 2500 as everything is just falling apart. I still don’t have a top dash, the kick panel under the steering column broke and fell off, the bezel that goes around the steering column cracked and fell off, the glove box door hinges broke, the overhead pushbutton lights broke, the hand holds on the door panels are cracked, and the HVAC control unit is cracked. Did I manage to get the truck with the single worst interior on the planet? I’m about ready to gut this garbage out and start from scratch.
