Charging system issues
- Replies 7
- Views 1.8k
dripley 2 posts
JAG1 1 post
01cummins4ever 1 post
Royal Squire 1 post
Popular Days
Secret. The minimum voltage that ISB Cummins will run is 8.00 Volts.
If your grid heaters are comming on at first start up that would be normal. When the heaters kick off is when you see your voltage rise back up to 14. and headlights back to normal.
The up and down voltage is from the grid heaters running. The cut in and in a cycle can draw about 90amps each. How cool is it out your way? I beleieve they kick in at below 60* IIRC.
My truck is a 2001 2500 ram with the 24 valve. When I first start my truck up in the morning I can see the alternator kicking on and off back and forth. It gets down to about 10 volts and then goes back up to 14. It’s so bad I can watch my headlights dim and get brighter, I am wondering if this is normal operation or not? I also have a problem with my truck shutting off at idle out of nowhere, wondering if the injection pump is getting low voltage every now and then causing it to shut the truck off. Then the truck starts right back up no problem. I have done the AC noise mod and replaced the alternator about a month ago. If the pcm controls the alternator cut in/ cut out I wonder if it was harmed from the AC voltage before I fixed that? Any help would be appreciated
