Coolant leak from back of head
- Replies 14
- Views 12k
Mopar1973Man 3 posts
Silverwolf2691 3 posts
Dieselfuture 2 posts
Hoopster 1 post
I'm updating this to help anyone who needs help with what to do when this freeze plug. I had access to a lower profile air drill, that is the biggest issue with fixing this while everythin
Hello everyone, first post but long time lurker. Last night i noticed a coolant leak coming from my truck on the ground while i was shopping. Was almost a 12" wet spot on the ground after about an hour and a half of sitting. After getting the truck home and letting it cool off for a bit i was able to find out where it was coming from. On the head in the back passenger corner there is a 45 degree spot that has a small hole, about 3/8" diameter. Is this a freeze plug and if so has anyone replaced it without taking the head off? Not a lot of room and its close to the exhaust so im not expecting a lot. Im also hoping to properly fix it after winter if this fix isnt long term..
Thanks in advance,
Silverwolf
