Alternator late to kick in, harder starts
- Replies 14
- Views 3.3k
KATOOM 3 posts
Dieselfuture 3 posts
Tractorman 3 posts
Mopar1973Man 2 posts
Popular Days
Technically, it's safest for your truck to jump start someone with your engine NOT running, key off.
I might still be using mine had it not failed in this way. I guess the bolt was not tight. Just wore its way thru. Still have it matter of fact. Figured I would find a way to fix it one day
Wonder if there are some kind of diode a person could install to prevent elec problem...to keep elec only going outbound from battery be used to jump disabled vehicle
So I'm dealing with a new issue. The truck is having some hesitation starting..and for some reason the alternator isn't kicking in for about a minute. Sometimes the voltage will drop off even after the alt has kicked in.
I did the w-t mod..but I haven't put a new line from the pdc to the passenger side battery..I know this isn't supposed to be necessary, but could it affect anything like what I'm describing? This issue didn't pop up after the mod..It's been about a month.
The only other thing that I can think of..is my gf used my truck to jump her car a couple times in the morning..I've never jumped anything before, and I wasn't present when she did it. Could the added load of jumping her car, whilst cycling the grid heaters on a cold truck, have caused any type of issue?
Any ideas what could be going on here? Here's a video
