- Replies 141
- Views 16.5k
Mopar1973Man 34 posts
Scottfunk 30 posts
Marcus2000monster 17 posts
pepsi71ocean 15 posts
Although somewhat indelicately said, I would mostly agree with this. There are basically three types of knowledge: the type of knowledge gained through personal experience, the type of knowledge gaine
agree this is not a tuning thing, I think it is a drag thing. the engine is working really hard to generate enough exhaust flow to get 11 psi at cruise state.
Not much to 24V injector. The little washer looking thing is a shim next to the body. The spring is a fairly heavy coil and rides directly on top of the shim. In all the injectors I've me
For those who aren't familiar my truck is a 96 GMC Yukon with an '02 24 Valve, it is backed by a 6 speed Allison transmission. The tires are 285/75/17 and I have regeared so that at cruising speed (70 MPH) I am right at 1960 RPM. I am currently getting about 10 MPG and I am trying to figure out why. I run a Quadzilla on standard tune, level 4 and I have a bit of a lead foot but most of my driving is freeway miles. I also run a FASS 150 and a 5" straight exhaust with 4" down pipe.
Now then...at cruising speed I am approximately 20% throttle and my EGT's are in the low to mid 800's. My load ranges between 30 and 36% based on the slope of the road. The boost at cruise is 11psi and I never really paid attention to the IAT's until recently but they stick in the mid 130's; because of space constraints I use an air to water intercooler and I noticed a drip from the filler cap recently so there's a chance the fluid is low. I recently adjusted the valve lash and I have plans to clean the IAT sensor and MAP sensor in the next week but from what I understand about the sensors if they were dirty they would read low not high. I am admittedly not an expert in the field, in fact this is the first diesel truck I've ever owned or even driven.
So the question is: Where can I start looking for inefficiencies or out of service conditions that are burning extra fuel? I would really like to take the old girl to the coast in the spring but at 10mpg I'd need a second on the house. Any help is appreciated.
