Losing power or sanity
- Replies 14
- Views 2.5k
skyhigh4by 5 posts
Mopar1973Man 4 posts
Ed ke6bnl 2 posts
Me78569 1 post
check your map sensor to ensure it is reading 0 at idle and increasing as you would expect. This is a typical feeling when a map sensor starts to read low.
Could be the Edge EZ is having issues also. I would disconnect it and run a solo tank and if it changes. Also check error codes with it removed after a drive to see if the Edge EZ was masking.
It was next on the list after transmission which I just did.
My truck has 110k miles, edge EZ, 4” exhaust, FASS lift pump, Suncoast triple disk, dynamic valvebody, and an Oregon fuel injection VP. The pump has around 20k miles on it never seen less than 14PSI at WOT, always with the FASS, and always had 2 stroke. It recently FEELS like I’m losing low end power. Very very little smoke ever no matter what tune the EZ is on. Just feels like lately I have to push the throttle a lot more to really get going but once it’s wound up then it seems fine. No CEL. New fuel filter. Also my fuel mileage sucks (250-300 miles/tank) Runs great otherwise. Could something be up or am I just losing my marbles??
Edited by skyhigh4by
