- Replies 21
- Views 2.8k
dripley 7 posts
JAG1 7 posts
Manimalmother 3 posts
Mopar1973Man 2 posts
Wow lots of Dave's. I'm one too! Where ya working at drip? I live in York SC and can use my shop at work in Rock Hill for anything needed. We have a full machine shop and I
Welcome Dave! I hope that broken ears isn't a Dave thing. I need my ears
Sometime it like a certain job tells you to just start with square one and get everything set right from the beginning. When everything is all ready including the place your working then everything go
Late last week I hear a noise very much like my starter bolts are backing off while starting the truck. Figure I will address when I get home. So rains on Saturday and misty and wet on Sunday. So I figure I will go back to SC on Monday morning and address it there.
I get to work and when it warms up some I go out there in parking lot with laborer and look under the truck and laying on the asphalt is a piece of the spacer and one of the bolts. Still cant believe those pieces hung on untill I parked. Anyway thw spacer is toast and I need a new. Used the parts look up tool, thanks @Me78569, get the part # and google it. Found many sources for the oe spacer. The cheapest I can find it is about $150. I did not paythat much for the starter. They also wanted $9 apiece for the bolts. F'ing unbelievable.
So I googled "starter motor spacer 02 ram 2500. To happiness multiple folks offering them from $55 to $70 with three new bolts. I bought these for $60 in aluminun, billett as they say.
So I thightened the bolts with pieces of the spacer to get by for acouple more days and the 3 or four times I had to go somewhere I parked on a hill.
The spacer arrives today and me a laborer go out to install it. First thing I see is one of the ears on the starter for the bolt to go thru has broken, a little over half of it still there. To late to getma starter and get it on so I decided to just put this one back on for now. Got it off replaced the spacer and gotmthe 2 bottom bolts on and was having a very difficult time getting the top bolt to start. F'ed around with it for 30 minutes, no success. Backed the other 2 bolts and low and behold the top bolt is broken off in the hole. The suns going down and I am SOL. Tightened the other two bolts and I guess a parking on a hill untill I can get and drill the bolt out. Sure looks like a lot of fun.
So I now have a big
on my forehead. Thought I was safe but man was I wrong.
