Fuse crimps
  • Replies 8
  • Views 2.6k
  • That accessory PDC looks like it may work for me.  I've got someone who wants my torque converter lockup system along with a grid heater bypass switch with resistors installed in their truck and this
  • Dieselfuture
    Dieselfuture
    I like the PDC box, but it would take me a year to clean my wiring mess up and put it all in that box
  • I feel your laughter!!!
That accessory PDC looks like it may work for me.  I've got someone who wants my torque converter lockup system along with a grid heater bypass switch with resistors installed in their truck and this should handle all the relays and power fuses I need to use.
@Mopar1973Man so I was thinking of the motor has rubber grommets on all 3 bolts is this motor still grounded to that plate? What should I do about adding another ground?
Well I just checked it. It is not passing an ohm test. 1548119252650701391533.jpg.663d11f1e3ebfcb252a55316da1232fd.jpg
I like the PDC box, but it would take me a year to clean my wiring mess up and put it all in that box :lmao:
Wait till you see my mess of a truck!
I don't have to see it... I've already heard about it. :whistle:
