- Replies 8
- Views 1.8k
Mopar1973Man 2 posts
Towrigdually 2 posts
Bullet 2 posts
Dieselfuture 1 post
Popular Days
Some good info there, some issues as well. Biggest thing is no you should not stack timing boxes. while he is right you can't "overtime" the collar in the pump you can command too much t
Tidbits... Max timing is 32° BTDC. Optimal fuel pressure 14 to 20 PSI Filtration should be 3 micron. Double stacking filters is a good thing. Most error codes are elect
Good stuff...thanks for posting! I'm smarter than I was 20 minutes ago. I have progressed from idiot to moron...clinically speaking. ?
dont know the fella, but follow him on instagram and he posted this. some decent info if others didnt know, some i didnt know either. really hope is continues to how he put the VP44 24v in his 1st gen truck.
