DAP Injector Upgrade 7 x 0.010 @ 320 Bar
- Replies 126
- Views 23.6k
Mopar1973Man 35 posts
pepsi71ocean 16 posts
Marcus2000monster 16 posts
NIsaacs 11 posts
Call it what you want.... You're addicted to the power. <— Mike
And you tried to tell us you didn’t have the power bug!
never less than 7 x .010's
I finally got the 7 x 0.0085 @ 305 bar removed and the 7 x 0.010 @ 320 bar installed. What I noticed right off the bat is the idle is MUCH smoother. Without changing any of my tune on the Quadzilla I had it on level 0 for extended warm up. Then I flip back to my max power level of 7. Once it warmed up it was a bit smokey. Quickly changed up my timing and a few timing setting and cleared a bunch of that up. Enough power it to break the tires loose in 3rd or 4th gear. I've got to play with the tune a bit to clean stuff up for sure.
+150 HP VCO 7 x 0.010 @ 320 bar are a excellent choice for Quadzilla Adrenaline.
