- Replies 15
- Views 4.4k
Unreal Summit 5 posts
JAG1 4 posts
dripley 3 posts
Dieselfuture 3 posts
Popular Days
Lucyyyyy, Ima gonna splode!!!!!
So I am about 95%sure it's the negative battery cable on the drivers side. I think I got her fixed for now. I'll report back if that ain't it.
Sorry my location ain't right. I am NC. VA line. It's about 18 before wind chill. It still working good so I need a new negative battery terminal. For a permanent fix.
This morning I started my truck like normal, waited for the wts light to go out and she fired up. Took a couple more rounds than normal. Grid heater cycled like always. Get in and get ready to roll and I see the CEL. I shut her down and check the code. 1291 and that companion code as well. 1693 or something like that. So I turned the key and wts came on and went off after about 6 secs. Started up did fine I went on. Got to work (35min drive) and shut her down. Turned the key and the wts stayed on just like it sat all night. Turned it off and back on and it went off with the rest of the lights. Same thing today after work. So what do I need to look at first? Could it be a bad ground making this happen.? Again the grid heater still works like normal.
