Dead truck P0216
Drove it home last night. Wouldn't start this morning. Has a P0126 code. Has fuel pressure out of the fuel filter. I am assuming a dead VP44. Who sells a good quality pump?
Edited by mcknight77
  • Replies 97
  • Views 15.9k
  • If anybody cares, the new VP44 is in the truck and it runs. FASS going in tomorrow.
  • I care..  i don't know if it's been talked about or not but what i found be really handy is shut off valves before and after fass pump.  Changing filters,  priming Etc   I'm did the fass pum
  • We all care and are glad that your problem is solved. We sometimes diverge from topic and have some fun. But ultimately helping to solve the problem is everyones goal here.     I hope to d
Sounds like it's time to pull out the spare P7100 and put it to good use........
8 hours ago, Bulldog said:
Crazy seeing people ok with a Vp-44 failing at sub 300k miles
I agree with what you're saying especially on a legendary Cummins  diesel. EPA had a lot to do with that and honestly if I can get 250-300k out of the pump I'm ok with that, on fly tuning compensates for longetivity for me. Now the pumps that lasted less than 100k is truly sad. I know there are a lot of variables as to why, but still.
I do miss my 12 valve with p7100 to a point, it was simple and it just ran. Didn't have to worry about AC noise or any of that crap. The body was falling apart, I wanted to put that entire drivetrain into a Suburban but never got time to do it :cry:
Here of late we have seen a few folks that got 250k 400kout of there oe pumps. Then we have many with short life spans on the oe pump. Mine only went 75k and @Mopar1973Mans only went 50k. Most of these on the old #2 diesel they were designed for. Longevity is bit all over the place.
Remember VE, VP44 and CP3 are all fuel lubricated. If the fuel is low in lubricity and poor quality filters used then these pump doesn't last as long. Being that Bosch design all these pumps for <460 HFRR fuels and today US fuels are all ~520 HFRR which enhances the wear. Hence why the 2 cycle oil theory came out.
P-pump is the only oil lubricated.  I don't suggest P-pump conversion unless you plan on racing on a track or dyno. This is the only pump without dynamic timing.
Unfortunately I'm used to working on highway tractor, and older designed diesels with inline injection pumps (Mercedes, Isuzu also) engines that go 1 million miles. My 12 valve was a scaled down version of those engines minus the sleeved block. Unlike other people I don't like being bent over for a new injection pump every hundred and fifty thousand miles @ $1200-$1400 a pop. They might be made of money, but even if I was Bill Gates I would not be spending that kind of cash on a failed pump design just on principle.
As a mechanical and electrical engineer I tell myself the following about the problem: Fuel lubrication of the injection pump fails? No Problem, don't lubricate with fuel! Can't pass EPA standards with the older style inline injection pumps? Then figure another way around it, without adding failure points to the design. Engineers are required to pull off miracles sometimes, we're used to it.
P7100 is my only logical option. I need extreme reliability. I could care less about anything else, even if it halved my horsepower, that's what I need. When I throw a gooseneck on the back of this truck and decide to go boar hunting in Texas, I need to know I will get there absolutely without issues. I can rebuilt this engine on the side of the road if I need to, but I don't want to, that's the point.
Just consider CR engine owner ever 100k to 150k miles putting $4,000 worth of injectors in. $1,100 VP44 is nothing compared to a CR engine. Then VP44 are lasting 200k to 300k miles.
DAP has a new revision of 028. Then it's less than a $1,000.
https://www.dieselautopower.com/bosch-027-vp44-fuel-injection-pump-standard-output-235hp-wire-tap-voids-1-year-warranty-vp44027year
Why is it say ho, but 235 instead of 245hp.
Maybe you can get a job proof reading adverts. I see a lot strange things like that these days.
It's probably a mistake, unless I don't know something, which is very likely.
I'm sorry for my observations, I was born that way :kick: if I was dumber, I'd be very happy with everything in my life, but noooo I have to go look for things to deal with
I am sure it is a mistake. Just another good reason to call before you buy. I van see you infront of a computer screen responding, "Dont these people know that you spell dumb a$$ with 2 ss and $$ signs".
Edited by dripley
You lost me there, but I'll probably get it in few days.
But I agree with what you're saying :think:
This is if you become a proof reader for a living. Not sure that is in your future Mr Future.
Lol ok I'm catching up, ya just never know.
I would rather purchase a rebuilt VP from the rebuilders and know which Bosch approved rebuilder did the work. Often a cheaper price distracts me away from such adverts and would rather talk with the people that are the hands on rebuilders and run the test stand for the VP44's. I like it when they take the time to show you around and a little bit about how it's done too.
6 minutes ago, JAG1 said:
I like it when they take the time to show you around and a little bit about how it's done.
That would be nice, but unfortunately not very many businesses do that anymore.
I figure if they have the time for you they have the time to do a better job and take pride in their work. I just don't like bean countin' money is everything attitudes. That gets me out of there and going somewhere else.
Conversely If the company makes customer service a priory and they are willing to help you out then your doing better. This is why i stick to DAP for my stuff for myself and other builds.
I see your point, but to me even being reliable I'm more concerned about other issues on my truck then my VP-44. These trucks aren't built to be semi's and run 500,000 miles, and IMO the P-44 is the last of the reliable mechanical engines.. Jumping into the CR era cost goes up, maintenance schedules drop everything seems to become less reliable as time marches forward.
OK, I just ordered parts from DAP. VP44, FASS95 system, and ISSO fuel pressure gauge kit.
I still feel lucky to have something as cheap and reliable as VP Cummins. Sure  the P-pump is reliable but IMO stock for stock doesn't have the pep and drivability of the VP. I'd buy a CR Cummins, preferably a 5.9 but even the 6.7 is ok. I will steer clear of anything using a CP4 like the 6.4 Powerstroke and the Duramax. It's WHEN, not if the CP4 fails it will take every other part in the fuel system with it including all 8 injectors and if equipped with a DPF it will kill the hydrocarbon dosing block and injector.  The 6.0 Powerstroke stroke is a decent engine after it gets head studs and illegal emissions modification, of course the HPOP and injectors can be costly especially for those trying to do extended oil drain intervals.
