- Replies 15
- Views 4.4k
Marcus2000monster 5 posts
Mopar1973Man 4 posts
Quadzilla Power 2 posts
astiles357 1 post
call quad
The that being said I would test the +5V pin for the 5V. Then for safety check the sensor ground to ECM ohm wise.
Did you jump it and let alternator charge dead batteries, or did you charge batteries with a charger. Were grid heaters cycling on top of that. You may have fried your alternator sending excessive AC
So the truck has been sitting for a month or so and the batte ries went dead. I unplugged the quad and jumped it and got it running. When I shut the truck off and plugged the quad back in it clicked the power on and off 3 times and then the truck stayed on.
When I then started the truck it loped and popped so bad it almost shut off so I killed the truck and not 2 seconds later the dash flashed 3 times an d the quad turned the truck back on.
I am now trying to connect it to a computer to see if I can update it but neither of the 2 computers I o wn (which worked before) even recognize the quad. I opened it and there is nothing broken or burnt insi de. Have you ever encountered something like this?
Thank you
