- Replies 16
- Views 3.8k
Unreal Summit 5 posts
Mopar1973Man 3 posts
Me78569 3 posts
int3man 2 posts
Popular Days
The front line is the "OUT" line going to the coolers. Putting a sender there will give you the highest and most active readings due to the fact that the fluid is coming straight out of the converter
Follow the front line from the trans. That's the pressure line. The return is the rear. If I remember right, the pressure line goes to the oil/water heat exchange on the passenger side block first, th
It will work there, however the sensors is a 100-240*f sensor. You may not get a reading until you have spent ~30-45 min on the road. I know in winter it wouldn't read anything unl
Not sure where this post is supposed to go, but I can't seem to get a transmission temp reading from my quad. It only says 100°. I have attached a photo of how I have it installed. Wafer, ring terminal, washer, lock washer, and nut right? I don't think u can really mess it up but what am I missing? I need a new wafer now because I broke mine... Any help is appreciated.
