xzt flash win 10
i have a xzt xzillerator tuner
trying to re flash but win 10 wont recognize the tuner does anyone know a work around for this without sending it back to quadzilla i dont have access to a pc with xp
  • Replies 43
  • Views 10k
  • hdpwipmonkey
    hdpwipmonkey
    Yep it's possible but I had to follow the video not the PDF.  There are differences between the two and when I followed the PDF it didn't work but when I followed the video it worked.
Go into the downloads section of the site.  They are all there stored.
i thought those were for the adrenaline only, i can use them on mine?
ok when I flashed with the 3000 tune truck was already warm so all was great but once the truckcooled down the 3000 tune also has high idle witch stalls the truck even though the xzt tune features guide says 3000 tune does not have the high idle or engine protection it def does is there a 3000 tune without high idle or maybe someone local to me with a smarty that would be willing to disable my factory high idle
ps manual high idle in off position works fine when engine is warm
can anyone help me with my quadzilla. I got a xzt and been fallowing these steps and have been all over these fourms. when I do step 2 I get devcon failed I tried all sorts of cords and such but nothing seems to fix it. im using the software quadzilla emailed me a couple days ago looks the same as yours. I don't get what im doing wrong I did step 1 a few times
Follow the video in the following link.  Use the video, not the PDF.  There are differences between the two and it don't always work.  Also do the steps exactly as instructed in the video.  I ran the video on my tablet as I did the install on my PC.
Hope this helps.
I will try again tomorrow but when I plug it in my computer doesnt make a sound or anything. The tune does have a little red light that turn on in the inside of it. I'm unsure what it is but I cant seem to get past the devcon failed
No sound when you plug in the xzt means the cable or the usb plug on the computer or tuner is not transmitting data.  You need a sound to happen
There are 2 variations of install software.  One for 32 bit windows and one for 64 bit.  Make sure you are using the correct one for your OS.  Other than that, I'm not sure why its not working.  :shrug:
Also, once you get it working make sure you flash an XZT tune to your box not an adrenaline one.  The instructions in the video are for the Adrenaline box but for the driver install portion its all the same.  Once your drivers are installed then head over to the downloads section of the forums here and download the XZT tunes.  Right click on the one you want to flash and click "run as administrator"  and the flash box should come up. :thumbup2:
I tried a bunch of cords and non of them made it make a sound even on another computer. But there is a little red light that comes on in my tuner. I got all the correct tuner files for xzt I got them from quadzilla. But I still cant get past devcon failed
What version of Windows are you using?
If you reboot your PC then you will have to redo step one to disable signed driver enforcement.  If you don't then the driver wont install.  Did you reboot at all after doing step 1 and before doing step 2?  Also, right click and run as administrator on everything.
I just re did step 1 and didn't restart before step 2 I did step 2 right after 1 right clicked and ran as administrator. I still get no sounds when I plug in my tuner but got devcon failed again.
I'm having trouble with this also I've read the manual install and followed the steps in the pdf and the video. I'm using a 32 bit windows 10 machine, step 1 goes successfully, but step 2 does not when I run it as administrator it just blinks the black box, but never stays open. So I've tried manually installing the driver via the device manager and its says its updated according to windows, however when I open the tunes folder the to update the module it will not connect with it. I've tried the process multiple times with no results. The xzt does beep every few seconds when plugged in.
Mine doesnt even beep it only had a red light that you can see if you look threw the plug on the other side.
I tried like 5 cables and went to the diesel shop here an got nothing I even used their tuner cable and it didn't even make a sound on their computer? All I get is the red light inside the box
One of the few reasons I love Linux. You can verify the USB connection and see the device plugged in. I know it's not very helpful. Like my example, my cell phone is plugged in. You can see my printer is a Canon. My keyboard and mouse. Etc.
michael@michael: ~_019.png
If the computer doesn't beep at you when you plug in the quad then you don't have a data transfer cable.
It should beep regardless of everything else.
