HELP! Flashing Wait to Start Light
- Replies 53
- Views 14.3k
gipperkid 26 posts
Mopar1973Man 7 posts
dripley 7 posts
Dieselfuture 5 posts
Didn't have time to work on the truck last night. But I made a jumper for the FASS relay and a test plug for the VP44.
You can put the different ECM in for testing purposes but I wouldn't leave it in for too long. You need to figure out what fried your ECM in the first place, seems that most common problems are altern
I'll try that as a last resort if all other troubleshooting fails.
So I have had the first major problem with my 02 2500. Got the truck out Saturday afternoon to go to a church dinner. Get ready to leave the dinner and my truck won't start. When I key-on the ignition I don't hear the FASS kick on, then I notice the wait to start is flashing. So obviously I am assuming the worst, a dead ECM. The truck would just crank and crank and crank. Call for tow and of course it will be awhile, so I leave the truck and wait at home.
(A side note, before I left the house that day when I first got in the truck and turned the key on, the FASS was delayed in kicking on. Thought it was weird, so I turned the key off and back on again and everything seemed fine. I figured it was just a fluke.)
2 and 1/2 hours later I get the call from the tow driver. I get there and of course human nature tells to try and start the truck. Turn the key on and the FASS kicks on, and the WTS illuminates with the normal delay since it was cool outside. The truck fires right up. I get out to thank the driver for coming and try to pay him for a dry run, and then the truck dies. WTS flashing and will just crank. So had it towed home.
Sunday morning same thing, key-on, no FASS, and flashing WTS. I decided to clean the battery grounds, they were somewhat corroded. After cleaning the grounds, truck fires up, runs for about 10 seconds and dies. WTS flashing. I then cleaned all the terminals. Now when I key-on, the FASS kicks on for the brief second, the WTS illuminates and stays on indicating for the grid heaters. But by now the batteries are so weak the truck won't turn over. I tried charging and boosting each battery, but it would barley crank.
So can weak or bad batteries cause this issue?
Intuition leads me to a bad ECM, but the truck ran a couple times, and the WTS is not delayed. I did the key trick for codes: P PCU - p1693, p1694, P ECU - showed no codes. But I will still put the scanner on it. Does this sound indicative of a bad ECM? I do NOT have a No BUS message either.
Bad IAT sensor? Bad grid heater relays? Bad grid heater? Corroded grounds?
Open to input, suggestions, any help!
Edited by gipperkid
