NV4500 temps with coolers
- Replies 37
- Views 7.1k
KATOOM 7 posts
Mopar1973Man 6 posts
Dieselfuture 6 posts
cuda 5 posts
Katoom, Any infrared measurement is factored by the emissivity of the surface. This is mainly a color thing, but is also actually affected by surface finish. In the calculati
Both stupid videos... I too can make YouTube videos and not prove anything.
Strangely random post for a transmission cooler thread. But...if you take the time to watch all of Gales differential cover videos you'll notice that he actually reveals nothing and merely trolls the
I installed some coolers from Genos garage. Now days there are a couple options, one is Fast Cooler that is a spacer that uses your original PTO cover, and the other is by Trans Cooler that is one piece and has fins inside. The fast cooler gives you 2 quarts extra when you install both and the Trans Cool only gives you 1 extra quart because of the fins inside taking up space that could be oil. I choose the Trans-cool version for 2 reason: 1: only one gasket to leak from instead of 2 per cooler. And 2: I thought the concept of having heat sinks inside may pull more heat to the outside. Who knows if it will and I might have burned myself out of an extra quart of cooling. Besides the quart mine give I added another quart in through the shifter tower. So six quarts of Red Line MT-85
It is real hard to direct compare before and after because the traffic for me living in the city changes so fast and so much. A 20 mile run to my shop this morning at 34 degrees outside with just the truck no trailer gave a case reading of 108 degrees with the factory mopar 85w oil that was getting real brown. The return run that had stop and go traffic but was near 60 degrees out was 108-110 on the steel case same point from the mornings measurement. But the new fins of the coolers heatsink where 97 to 113. And the close fin on the heatsink by the exhaust was 132 and 150 on the exhaust. I am adding a link to a thermal image and the regular image for clarity. The addition of using the Red Line 85 made no difference shifting wise from how it was before it is the exact same.
Edited by cuda
