- Replies 19
- Views 4.8k
Ravewolf 9 posts
dripley 6 posts
Mopar1973Man 2 posts
Me78569 1 post
Popular Days
On my truck if I reconnect the negative terminals, passanger first, the pump will run with the key off and maybe in my pocket. If I do driver side first it will not. No clue as to why. I never heard t
Crack open an injector line or 3 and see if you have fuel. The reasoning behind checking the batteries is you have a no start issue that requires boosting the batteries to start the motor
That is above my paygrade. @Quadzilla Power could answer that.
Ok, so my truck has an electrical draw (among the myriad of other things) so I went to start it yesterday, and the batteries were dead. I hooked up a charger to the passenger side and let the charger trickle charge all night. Still wouldn't start today. I had a friend bring over a big wheeled battery charger, and hooked it up, but remembered I needed to disconnect the adrenaline adr box first. I did, got the truck to start, let it idle for about 20 minutes to charge the batteries, then shut it down and hooked up the adr box. Immediately, with the key off and in my hand, I heard the cluster ding, and a few seconds later my fuel pump primed. Weird, but ok. I tried to start the truck, but nothing. I'm getting fuel, but the truck acts like it's not pushing the fuel.
I disconnected the negative cables on the batteries, and did a 30 minute hard reset. I rehooked the adr box back up, then the negatives, and as soon as the truck got power the pump primed again like the key was on. But the ignition is off, key in my pocket. I tried again, no. Dice.
Did I fry the box?
