- Replies 12
- Views 6.6k
Old Blue - 1998.5 3 posts
keithb7 3 posts
CUMMINSDIESELPWR 1 post
TBurg73 1 post
A word of caution and advice.... I purchased a Herko pump for my 1998.5 3500 4x4 Quad Cab with auto trans in 2016. It was to be used as a priming pump only, as at that time I had converted
Those times when the VP is getting the hottest is when you need to stay above 14 psi. Going uphills hauling heavy, you should never see below 14 and many others like myself know the variations between
Look at it this way... The minimum oil pressure is 10 PSI at idle and 30 PSI at 2,000 RPM. How long would you expect an engine to last with oil pressure dipping down close to the minimum values?
Before I lay down big bucks for a FASS or Airdog I decided to give the Herko fuel lift pump a try. 1998.5 Ram 2500 Cummins 5.9L 24V.
The Herko pump Installed pretty easily. I had to grind one corner off the mounting plate on the pump to make it fit. My stock location is left rear of engine block. My Herko pump did not come with the 90 degree adaptor for the fuel line from tank hook up. It is not needed. I was able to clip my stock fuel line on to it no problem. The rest of the details and psi readings are here in the video.
Yep a FASS or Airdog is likely in my future. We'll see how this Made In China Herko pump holds up. I can monitor it with my gauge. I will carry my spare stock Carter pump for long trips!
Stock Carter 10 psi at Idle. Drops to 6.5 psi pulling hard on a hill. Herko pump 16 psi at idle. Drops to 9 psi pulling hard on a hill.
https://youtu.be/JzvnjtBpQIw
Edited by keithb7
