Assistance Deciphering Proper Turbo And Job Planning Assistance
- Replies 15
- Views 2.2k
keithb7 5 posts
Dieselfuture 3 posts
dripley 2 posts
trreed 2 posts
I wouldn't worry about changing the oil. I've installed a handful of different turbos on my pickup, and have only changed the oil once, and that was only because I was an idiot and started it with th
98.5 to 2000ALL & 01-02 Manual was an HX35 platform some/most being an hx35W ( wastegated) 2001-2002 AUTO was the hy35W the hx 35 is bolt on upgrade to the hy, with a 62/65/12 bei
You can rebuild it for 50 bucks plush shipping with genuine holset kit from dap, diesel auto power. If the shaft didn't groove housing and compressor wheel didn't hit compressor housing. If it's leaki
1998.5 24V Automatic tranny 4x4 2500.
Hi folks. I have a considerable amount of turbo end shaft play. 208,800 miles. I have not checked boost pressure however I see oil is dripping off exit hose & clamp at ATAAC. I suspect I am pushing oil though the ATAAC as the turbo shaft seals and bearings are failing. Looking at stock turbo replacement options. I am planning to stick with stock size.
Looking at replacement turbo options for a 1998 year I see a few choices. Some state "For Engine Vin code D". I assume that means diesel? Other turbo options read for "Engine VIN 6". I am unsure what that means,
My engine tag is below. I don't see anything labeled VIN code. Maybe I need to look elsewhere? Perhaps 1998 options listed are covering both the 12V and 24V engine turbo options.
Perhaps I should look at 1999 turbo options. There are fewer options listed. I am in Canada. There are a few turbos listed under 1998 year "With Canada Emissions". I assume this I need? I believe the stock turbo on my engine is a Holset HX35. I will confirm later.
Another issue the oil in my ATAAC. I assume I need to pull the ATAAC and have it properly cleaned and tested to ensure good flow again. What other tasks can I expect once I get in there?
This is my first time personally doing this work so tips are appreciated. I will change all gaskets and planning new turbo oil line too. What about the soft hoses in the intake?
Thanks in advance.
