Welcome To Mopar1973Man.Com LLC
We are privately owned, with access to a professional Diesel Mechanic, who can provide additional support for Dodge Ram Cummins Diesel vehicles. Many detailed information is FREE and available to read. However, in order to interact directly with our Diesel Mechanic, Michael, by phone, via zoom, or as the web-based option, Subscription Plans are offered that will enable these and other features.  Go to the Subscription Page and Select a desired plan. At any time you wish to cancel the Subscription, click Subscription Page, select the 'Cancel' button, and it will be canceled. For your convenience, all subscriptions are on auto-renewal.
 I got a 2.3 vtec that I drive every day for work 160 ml a day and every Friday I add almost a quart of oil maybe 800ml. I read that a lot of people have this issue where vtecs consume oil. It did it when I first bought it few years ago, but I was consuming around 600ml, so it went up slightly. It now has 227k on the clock. I checked compression and all cylinders are the same, I did not do leak down test yet. I believe po ran it low on oil and scuffed-up cylinder number one, or it has broken rings on number one. I took all spark plugs out and 2,3,4 look good and clean and looks good inside the cylinder, 1 is ugly and cylinder is wet, it seems to be oil residue. So I believe that's where all my oil is going. Unless I have a stuck open injector. It doesn't smoke on If it doesn't smoke on startups no matter how long it sits, so I believe valves and seals are good.
Another issue developed recently check engine light came on for EGR valve and a lot of times when I come to a stop it wants to stall and die and sometimes it does stall die. Will EGR valve cause that problem, I feel like it's more related to idle air control or simply when the engine is hot cylinder 1 is barely working and I'm running on 3 cylinders and that's why it's trying to die. When it's almost dying I can hear what sounds like a vacuum leak, checked all the hoses and connectors and seems to be good, of course I could have missed a connection someplace I will keep looking.
What you guys thinking, @Mopar1973Man @IBMobile and anyone else wants to share their experiences
This is cylinder one that's probably the culprit
  • Replies 31
  • Views 21.2k
  • A leak down test is the tell all.  If you have a broken ring or bad valve it will show up here.  That looks like oil deposit fouling on that plug.   A stuck open EGR will cause a roug
  • Pre 1989 no OBD systems. 1989-1995 OBD1 with check engine light era where each car manufacture had their own codes and code retravel system.  1996-present OBDII codes P0100-P0999 and retriev
    EGR valve is nothing more than a vacuum leak to exhaust stream. I would do a test on compression and see if the cylinder has damage. Then do a vacuum test to see if there is valve damage. You might pu
EGR valve is nothing more than a vacuum leak to exhaust stream. I would do a test on compression and see if the cylinder has damage. Then do a vacuum test to see if there is valve damage. You might pull the EGR valve and make a block off plate for test purpose. I typically make the block off from an old pop can.
Thats an ugly spark plug. That is also about as far as my knowledge goes for any help.
A stuck open EGR will cause a rough idle and stalling as well as a cracked EGR pipe between the valve and intake manifold.  Check for fault code like P0401.
If you had a leaking injector then there would be a code for a bad injector, to rich, or to lean.  A vacuum leak will trigger a to rich code.
Edited by IBMobile
This isn't going to be much help, but every Honda I've owned burned oil. They all ran great, but I had to keep a close eye on it.
Thanks gentleman, I will trouble shoot some more. If i ever figure it out I'll let you know. But pretty sure cylinder 1 has oil in it from bad ring is my guess.
I do have a code for EGR, that's when it started to die on me too, so hopefully that's all it is for that part. As long as oil consumption doesn't get worse I'll keep driving it.
80-90 gear oil for the summer..........................
I put a quart of Lucas oil stabilizer in, that thick honey stuff and it still burned same amount. It seems if I stay below 3k rpm it does ok, if I get on it there and there then it chugs oil.
Makes sense to me. I always blamed my oil consumption on the Honda motors being too high-revving for their own good.
If it's got a PVC valve take it out shake it if it rattles okay you're good but doesn't rattle get another one
That was the first thing I changed hoping it did a trick, unfortunately it did not.
One more thing I didn't mention. My throttle was sticky, I thought it was a cable catching, got everything lubricated and it was still catching. Took the intake hose off and found a lot of gummy gooey stuff inside the throttle body. Got it all cleaned with carb clean, so butterfly doesn't stick in that gooey mess. I think because of this Blow by its shoving too much oil vapor into the intake
Check it again after a week of driving.  Get that EGR problem taken care of first so it's drivable..
Oh it's drivable :rolleyes: I have to push gas and brake with one foot to keep it from stalling, like driving a stock car ha ha. It's a 5 speed
It's a 5 speed
Keep driving it like that and it soon will be a no speed.
I feel your humor :lmao2: it will give me more reasons to drive the truck daily :burnout:
Wife says sell it while it's still running, I'm like for how much 1k if I'm lucky, what am I going to get for that. It already paid for itself long ago, every mile going forward is a bonus. Been using oil since I got it almost 80k ago runs good on the hwy and gets 35-37mpg
I'll try working on it this weekend and see what I find.
If you can get the idle fixed then drive it till it drops.  It would cost you more than $1,000 in the first year on a new car.  A quart of oil every 600-800 miles is cheap compared to paying for a new car.   Walmart's brand is $12.78  for a 5 qtr. jug.
Exactly my thoughts, I chanel it every 10k but by the time I do I add like 8qts lol so it's fresh. I get a wix filter that's slightly bigger for longer intervals
@IBMobile  I cleaned the EGR valve it was all carboned up, it seems to cure stalling issue. Next time it does it I'll probably just block it off and leave sensor plugged in.
Time to make a block off gasket. I was doing that back in the 1980's for the older 1970's cars in Cally. Use to sneak right on through the smog check and pass easily.
Glad to hear it was that easy to fix, happy motoring.
That sensor is used to monitor the flow of exhaust gas by the increase in heat when the gas is flowing to the intake manifold.   When the EGR valve is commanded open and there is no increase in temp then the check engine light is turned on and P code is set,   This is an automatic fail in Cali.
What's weird is, I blocked it off on my 88 GT Mustang I had about 15 years ago and it never did set code or light. I think that was about the only vehicle I blocked it off on.
Did This Forum Post Help You?
Show the author some love by liking their post!
