Mechanical lift pump
I have been looking for a replacement lift pump and am leaning towards a mechanical pump.  Are there any major differences between the Fuel Boss and the Predator? Anything that makes one so much better than the other such as quality of parts, kit completeness, customer service, etc? This will be going on the truck in my signature plumbed in with the stock filter for now. Im trying to build a reliable low maintenance driver/tow truck, not some high hp toy. Thanks for any opinions/experience that you can provide.
  • Replies 92
  • Views 24.2k
  • Dieselfuture
    Dieselfuture
    I have a smaller tool box that I filled with random tools I had laying around, been in the truck for about 4 years now, used it few times and it was never for myself. Not saying that one day I won't n
  • One reason the fuel pumps are in or near the fuel tank is not because its pushing the fuel but rather it's pressurizing the fuel in the lines to keep the fuel from boiling and causing vapor lock.   Ga
  • My impression is the Fuel Boss has been out the longest of any mechanical lift pumps and there are not many complaints about them.
I like the quad xzt a lot. I can’t compare it to the other canned tuners being it’s the only one I’ve had, If gives a nice little boost of power paired with the 275’s. It pretty much lives on level 2 with just normal driving, but use level 3 when pulling the 5ver and other equipment.  Well worth the money imho.
I will be ditching the hy35 in the near future, and going with the hx35, it should allow me to hammer down a little more on the hills pulling a load without killing the egt’s
The Fuel Boss was waiting for me Thursday when i got home from work. Had it installed and running that evening. I went mechanical only. I hit the local Parker store and got 2 M12x1.50 to 6 jic fittings and 2 push lock 6 jic 90's. Got a push lock gauge T from Amazon and had enough hose in the Glacier kit to make a line between the filter and VP44. Fired the truck up before replacing the filter to VP line. Fuel pressure was right at 17psi. Replaced the filter to VP line next. Was fighting dark and forgot to refill filter housing with diesel before starting truck. Truck started and ran for about 30 seconds then died. After 30 seconds of cranking truck fired and stayed running. I was shocked I didnt have to bleed the lines.  After a couple days of driving fuel pressure is right at 17 psi at idle.
The first 30 seconds of running did most of the priming.  That pump moves so much fuel at such a low rpm that the last 30 seconds topped it off.  I went straight mechanical too...much easier and saved $50.  You should hit around 19 psi when you get on the gas...which is perfect.
@Bullet I've seen 19-20 psi getting on it pretty hard. Much better than the 12 psi idle, 8 during cruise, and the random drop to 2 that the factory pump was doing.
Sounds just right.  Yeah you'll be happy to do away with the electrics.  I'm at 18 idle and 20 when I get on it a bit so pretty much the same as you.  Those belts are good for 50k mile change intervals so you shouldn't have to address it again for a while.  I carry an extra belt in the truck just in case but I suppose I won't ever need it.
Ordered a spare belt when i got the kit. Now i just need to quit screwing around and put together a small tool kit. Figure a 50 cal can with basic tools won't take up too much room.
I have a smaller tool box that I filled with random tools I had laying around, been in the truck for about 4 years now, used it few times and it was never for myself. Not saying that one day I won't need it, in fact the reason I put it in the back in the first place is because I was in the pinch one time and it would have been nice to have tools and tire plugs, along with an air compressor. Oh well others can benefit from it for now, maybe someday it will come in handy, but I hope not.
Best thing to do is preventive maintenance and check things thoroughly every so often,  then that leaves you big items like vp, water pump, alternator, any pulley that is spinning...etc. you just can't have enough parts to drive around with.
But a basic tool kit that is nice to have for peace of mind, it's just where do you draw the line what to carry on board. Guns and cash will solve most of the problems :gun: :spend:
Thats why I use 50 cal ammo cans. I'm a mechanic and hate other people touching my cars. I can fit basic tools needed, waterproof, compact. Having a spare belt for fuel pump is useless if I don't even have a 1/2" wrench to change it with. I have an onboard air system I swapped over from my old truck and i keep an old 1/2" impact and socket for lug nuts in truck now. I was towing a buddies car and had a blowout on my trailer a couple years ago and we had the tire changed in 4 minutes in the mud on the side of 65 North.
We got a few looks dragging this thing behind my old gasser.
my only recommendation when ordering a fuel boss, or shortly there after, is order a spare lower pulley. mine has dried out ( and being a fiberous material) and has started to seperate the belt retaining edge.
it hasnt fallen off completely, but about 50% is not attached.
I haven't heard of this issue before but definitely something to look into...thanks for the heads up on it.
@Stormin08 How long did you you have the Fuel Boss on before the pulley started to come apart?
Nice Ferrari!  Is that a Maranello?
It belongs to my buddy. If i remember its a 1995 F355. Its a beautiful car but I'm not really up on my imports. I've only seen it twice, haven't even got to hear it run yet. Hoping to get to drive it this summer. That thing was about 1" narrower than my trailer rails and we loaded it, not running and on an uphill slope, to take to a shop in Indianapolis for timing belt replacement and exhaust install. I was supposed to get to help drive it home but the shop delivered it for him.
honestly i cannot recall, i did the install back in 2014, and noticed it some years later when changing the serpentine belt.
that also is the only down side, you must remove the fuel boss belt to service the serpentine...that is also a down side....serpentine breaks, you loose the fuel boss belt.
A serpentine belt breaking is usually caused by some other problem and really is rare. Normal repairs I usually just let the belt hang off to the side so to me thats not that big of a deal. The pulley falling apart you spoke of is something I'll keep an eye on. Thanks for the heads up. I had a Moroso belt drive water pump kit that used the same style pulleys and belt on one of my old hot rods. It was on there 10-12 years with no problems. I hope to have the same luck with the Fuel Boss parts.
Could the Fuel Boss be installed on a truck that has a FASS system on it? Using the HOBBS would shut the FASS off after the engine was started.
From what I was told by Glacier Diesel and what I've read it can be installed with any electric lift pump. You just have to get the correct fittings. I'm new to the Fuel Boss though and would call Glacier. I'd bet you're not the first to do it.
Yes...the standard kit comes with a Hobbs switch and the necessary fittings to plumb it in with the stock Carter pump in it's stock location as a backup and fuel filter housing primer.  But I found it not necessary to have a backup or need help with priming.  It's a solid setup on its own.
mine has the factory filter, FASS DDRP, 3/8 lines from stock hard line up, and the fuel boss...i only bump the fass occasionally to keep it working.
Did you mean to check and see if it's still working? :wink:
