Brakes, power steering
- Replies 119
- Views 21k
portlandareae28 40 posts
Mopar1973Man 12 posts
wil440 11 posts
dripley 9 posts
When was the last time you changed the power steering fluid? Remember Power Steering fluid need to be changed every 30k miles.
I got a vacuum pump rebuild from Gould. And new ps lines and a new ps pump both borgson. All three are you get at Genos Garage. There's even a video straight from gould on how to do the vacuum pump re
Put a cap or plug of some sort on the reservoir nipple where you took the hose off so the oil stays in the reservoir during the process. I cut a short piece of rubber line, stuffed a bolt in the end t
Drove the truck over 100miles today, hasn’t done any kind of distance in awhile. After about 30 miles, started to feel gravelly pedals, both brake and clutch felt weird, when pressed felt gravelly under my feet. Braking seemed a little weak too and power steering more intermittent than normal. At about mile 40 had to brake hard compared to normal braking and the truck pulled left... not sure where to start my chase, any thoughts?
