- Replies 14
- Views 3.4k
98whitelightnin 4 posts
WiscoRedkneck 4 posts
Mopar1973Man 2 posts
JAG1 2 posts
I never had a single problem with my vp in my old 98 but I got a good deal on p-pump and all swap parts so I made the swap. Never had a single issue with that setup either and actually got my best mpg
I agree, especially since he stripped the block down.
No crack in block, block is a 53 block. I just bought another truck so the time crunch is not on the table, not to mention most of the work is being done by my good friend who is an ASE heavy mechani
So my Cummins 53 block with 387,000 and change lost compression along with other issues in cylinder 5 and 6 this still stems from the previous post about injection pump failure.
I intend to rebuild so looking at options
1- find 24 valve non 53 donor rebuild and install or if in good enough shape don't rebuild
2- buy a 12 valve rebuild with donor parts from 24 valve pistons head and such and make p-pumped 24 valve.
Right now it seems cheaper and an overall better option to go for number 2.
Tell me what you guys and gals think I need to make a wise choice here the next 400k depend on it.... lol
