- Replies 56
- Views 13.7k
Alexio Auditore 15 posts
Evan 12 posts
Mopar1973Man 6 posts
Stormin08 5 posts
i wouldnt call it a band aid, a conversion yes... the design that the LUKES accomplish is what MY NAPA design is... a metal on metal ball stud design that is greaseable. only
BIG NOTE HERE.... certain parts are easier to replace if need by the parts house...i remember calling a couple to see what was more readily available...then i cut the other side. that way
personally, i wold just go with a parts house brand (napa mainly) with a warranty, the mopar fails as regularly and is harded to warranty. on a stock height, trimming the draglink maybe ne
So it seems this is the summer where all the problems start showing, leaking p.s. pump, passenger axel seal leak, front brakes, and now tie rod ends. Not enough time in a day to adress it, but will be making time here pretty quick.
So I know there is a 4th gen conversion I can do for the t style setup, but is it worth it? I still have 16s on my truck, so I'd have to grind off a knuckle or two for it to fit right?
What's the price for one and who would be a reputable vendor for it?
And are there any problems to worry about with the 4th gen setup? Like recalls and such?
Other wise I saw Luke's links has all four greasable ones I can install for about 255 bucks.
I'm sure napa has some cheapy garbage, but I've about had it with cheap parts not lasting at all. (just replaced water pump again 2 years after already fixing it with a new one, not rebuilt, Napa brand(gates))
Still running 265s on my truck too, nothing oversized that would be hard on the front end. I would like to upgrade to 17s 4th gen wheels, but that's someday in the future.
