- Replies 18
- Views 5k
dripley 6 posts
xtreme95cummins 4 posts
IBMobile 3 posts
JAG1 2 posts
Its because the fuel is running out of the lines. The fuel system must retain a "prime" whereby the fuel stays in the lines when the engine is off. Also, there is NO pressure in the fuel lines/syste
Lower pressure while cranking is normal. the ECM is doing that. You are most likely loosing the prime in the fuel system. By that I mean air is getting in some where. The return line from the back of
They're sealing washers. DAP or Vulcan has them. $9.38 will buy alot more than one. IIRC they are the same as the ones on the OE connection to the VP..
Hey guys... My truck has been giving me a hard time starting. It started happening last year and only did it when I was parked nose uphill. I remember reading something about this one time a few years back... but never heard what the cause was. This year.. a few months ago.. it's been starting hard on level ground. I have to hold the key on for 10-15 secs til it fires up. Almost like leaving it unplugged on cold days of winter. This only happens the first start of the day and only if I let it sit for more than 24 hours. Where do I start? No pun intended.... Thanks
